Mises à jour de la version 2013
tom
MessagePosté le: Lun 10 Juin 2013 - 17:35    Sujet du message: Mises à jour de la version 2013 Répondre en citant
la hotline peut te fournir un patch qui résout le problème de l'ordre de la biblio de symboles...(patch 2013-1)
J'avais essayé de le mettre en ligne, en vain...
A bientôt
MessagePosté le: Lun 10 Juin 2013 - 17:35    Sujet du message: Publicité
christof
MessagePosté le: Lun 10 Juin 2013 - 17:54    Sujet du message: Mises à jour de la version 2013 Répondre en citant
ok merci je vais voir avec la hot line
a+
MessagePosté le: Mar 2 Juil 2013 - 15:18    Sujet du message: Mises à jour de la version 2013 Répondre en citant
Nouvelle mise à jour 2013-1-4
General
Editing and correcting various messages issued by Quality Reporter led to a more stable Allplan.
New NVIDIA graphics card drivers are installed correctly in conjunction with specific hardware.
File permissions are checked more quickly when you upgrade on a network. Note: this improvement only applies when you use the full Allplan 2013-1-4 version for the upgrade.
Allplan Exchange
All languages in Allplan Exchange use the YYYY-MM-DD date format, facilitating international data exchange.
The program issues a message when it cancels the upload process of a file due to missing hard disk space.
"AllplanExchange_FormatSettings.xml" is adjusted whenever you insert new formats, keeping the file size to a minimum.
Basics
IFC
Now you can import specific IFC files with vectors outside the permitted range.
Files used in a workgroup environment are locked for IFC export; a corresponding message is issued.
Plot Layout
Changing the printer properties in the "Plot Layouts" tool no longer affects the default setting for the document size in the Windows printer properties.
Switching between color and black/white printers is saved correctly in the file with the default values for plotting.
Arcs with large radii print correctly.
Architecture
Smart Symbol
Custom smart symbols created in earlier versions can be moved in the z direction when you use "Select Elements Intersected by Selection Window Only".
Stairs
When you modify a stair using the "Stair Wizard", the rise number is no longer reduced automatically.
FM Manager
Changing the symbol for the door swing no longer affects the link between the smart symbol and the FM object.
Engineering
Reports
Multiple drawing files included in reinforcement reports are loaded correctly.
The height of bending shape text is displayed correctly in the "Reinforcement schedule - bending shapes" report.
Allplan International
Switzerland
You can assign the 'TF' occupancy type to new rooms.
Les membres suivants remercient Graphitus pour ce message :
PHILC (02/07/13), bco (02/07/13), HB (02/07/13), Lemmy (03/07/13), Dominici Gilles (03/07/13)
MessagePosté le: Mer 11 Sep 2013 - 09:16    Sujet du message: Mises à jour de la version 2013 Répondre en citant
Hotfix Allplan 2013-1-5
Release Notes
General
Softlock License Manager can be installed on Windows 8 x64 again (with all current patches). Note: this improvement only applies when you use the Allplan 2013-1-5 installation package.
Basics
The assignment of empty drawing files to a fileset is retained again when you insert a drawing file using 'Import Drawing Files and Layouts with Resources to Project'.
You can use the new domain names to log in to the Allplan websites on the Web palette; it is possible to log in straight from the palette again.
Interfaces
Dimension text and elevation points are given the text size appropriate to the reference scale when they are exploded before being exported to AutoCAD.
Plot Layouts
All the settings in the Windows Print dialog box are saved and used for printing.
The setting of user-defined formats in the Windows Print dialog box is transferred to the 'Output' tab of the 'Plot Layouts' dialog box and used for plotting.
The color-pen assignment is retained during plotting even if Windows Search Service accesses the file with the default values.
Analyses of layouts using the 'Layout contents' reports no longer affect the drawing file assignment of the current fileset.
Architecture
Rooms, Surfaces, Stories
The factor in the 'Redefine Rooms, Surfaces, Stories' tool is preset to 1.0 again.
Engineering
Mesh Reinforcement
Mesh cutting diagrams are optimized correctly again.
Romania
Improved reinforcement reports.
Les membres suivants remercient Lemmy pour ce message :
PHILC (11/09/13), bco (11/09/13)
MessagePosté le: Mer 11 Sep 2013 - 10:23    Sujet du message: Mises à jour de la version 2013 Répondre en citant
Est ce qu'une version 2014 est programmé prochainement?
Quelqu'un a des infos?
MessagePosté le: Mer 11 Sep 2013 - 10:41    Sujet du message: Mises à jour de la version 2013 Répondre en citant
Oui, la version 2014 est en phase Beta (beta 2 pour être précis).
Et il y a quelques bonnes petites choses... mais chut, je n'ai pas le droit d'en dire plus...
Sortie en Octobre, comme chaque année, a priori, mais peut-être qu'en France ce sera légèrement décalé en fonction de l'organisation du Tour de présentation (Allplan BIM Tour)
MessagePosté le: Jeu 12 Sep 2013 - 09:03    Sujet du message: Mises à jour de la version 2013 Répondre en citant
Allez, une petite info croustillante ? Du neuf sur les vue associatives ?
MessagePosté le: Jeu 12 Sep 2013 - 09:55    Sujet du message: Mises à jour de la version 2013 Répondre en citant
Tu devra attendre un peu Mr. Green , mais effectivement il y a pas mal de bonne choses
MessagePosté le: Jeu 12 Sep 2013 - 17:26    Sujet du message: Mises à jour de la version 2013 Répondre en citant
Tu as des infos ?...
MessagePosté le: Jeu 12 Sep 2013 - 17:30    Sujet du message: Mises à jour de la version 2013 Répondre en citant
il bluffe Mr. Green
MessagePosté le: Jeu 12 Sep 2013 - 17:46    Sujet du message: Mises à jour de la version 2013 Répondre en citant
MessagePosté le: Jeu 12 Sep 2013 - 17:57    Sujet du message: Mises à jour de la version 2013 Répondre en citant
Bon, en tout cas, il y a des bonnes choses à venir dans cette V2014, mais qu'y aura-t-il dans la version 2015 ?! Very Happy
MessagePosté le: Ven 13 Sep 2013 - 08:11    Sujet du message: Mises à jour de la version 2013 Répondre en citant
MessagePosté le: Ven 13 Sep 2013 - 08:22    Sujet du message: Mises à jour de la version 2013 Répondre en citant
Un grand moment de bonheur, merci...
MessagePosté le: Mer 2 Oct 2013 - 20:18    Sujet du message: Mises à jour de la version 2013 Répondre en citant
Hotfix Allplan 2013-1-6
Release Notes
General
Installation program for hotfixes has been improved.
There are no longer any problems that might have occurred when you opened dialog boxes for opening/saving Windows files on computers running Windows 7 64-bit versions.
Basics
Plot Layout
Congruent layout elements can be placed in layout windows again.
The default for saving printer settings is switched on in the registry.
Printing with Allplan vector drivers has been improved.
Lemmy (03/10/13)
MessagePosté le: Mer 2 Oct 2013 - 21:10    Sujet du message: Mises à jour de la version 2013 Répondre en citant
Olivier, .... t'es chiant quand tu parles en anglais...
Mr. Green
MessagePosté le: Aujourd’hui à 06:42    Sujet du message: Mises à jour de la version 2013
Page 5 sur 6
