Mises à jour Allplan 2016
Aller à la page: <  1, 2, 3, 4, 5, 6, 7, 8  >
MessagePosté le: Jeu 17 Sep 2015 - 20:26    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Hotfix Allplan 2016-0-3
Release Notes
General
Allplan and Windows 10
You can now use Allplan in conjunction with notebooks running Windows 10.
Quality Reporter correctly recognizes and displays Windows 10.
Hotinfo correctly recognizes and displays Windows 10.
Setup, Licensing, Auto-Update
We stabilized and improved WIBU licensing for Allplan in various places.
If the license server cannot display licenses due to missing administrator privileges, you get a corresponding message.
When you install Allplan as a viewer, Setup automatically chooses the country that is set for 'Region and Language' on the Windows Control Panel.
It is no longer possible to stop Allplan Auto-Update, making sure all software components always update correctly.
We improved Auto-Update, making sure the update runs through even if the Internet connection gets lost.
Services application
When importing project backups from Allplan 2014 and 2013, you now have the option to convert the data and to import them into a new project.
After having upgraded, you can no longer select the 'Hardlock' (dongle) option.
Building structure
You can rename drawing files in the building structure quickly and easily.
Basic
Interfaces
DWG interface
DWG export takes into account arcs between clothoids in composite elements.
DGN interface
Point symbols get the correct size when you export complex layouts to DGN.
BIM+ interface
Allplan transfers default attributes and user-defined attributes to BIM+.
Allplan transfers its internal element numbers to BIM+.
Allplan does not update objects that have not changed when you export data to BIM+.
iTWO interface
Finish specifications identified as areas to be subtracted (with the factor -1) are correctly exported to iTWO.
Layout
The 'Print Layouts' tool does not take into account margins when you choose PDF export and define a resizing factor.
Architecture
Walls, Openings, Components
When defining the 'Sill Height', you can enter any value for deltaBL (for example, for the floor structure).
Engineering
Bar Reinforcement
Using 'Convert, Match Elements', you can place design entities converted to reinforcing bars one after the other.
When modifying a linear bar placement, you can redefine the placing line in the 'Placing region' area of the 'Properties' palette.
Steel information and bending information you created for area reinforcement placed in polygon (with 'Bending Machine' in the BVBS standard) get the correct number of pieces.
Using 'Modify Placement', you can change the number of pieces quickly and easily a number of times.
FRILO Plate
We stabilized export of complex plates with large radii to Frilo. The FE program of FRILO Software GmbH cannot process circular beams. Therefore, you cannot export these components.
Terrain
Site Plan
We increased the maximum values you can enter for the reference height in 'Modify Terrain Point Height'.
Presentation
Animation
You can quickly and easily save custom surfaces as favorite files straight from the 'Surfaces' palette.
Allplan International
As soon as Auto-Update is complete, you get a message. This message is in the selected language.
MessagePosté le: Jeu 17 Sep 2015 - 20:26    Sujet du message: Publicité
MessagePosté le: Lun 21 Sep 2015 - 11:42    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
2 remarques par rapport à cette dernière mise à jour :
- pourquoi "It is no longer possible to stop Allplan Auto-Update, making sure all software components always update correctly" ?
Il s'est avéré par le passé que des mises à jour pouvaient être très gênantes, je pense au bug des cartes Nvidia entre autres. Perso, j'aime bien attendre un peu avant d'installer des MAJ, surtout si je n'ai pas de problème particulier. Là, c'est une obligation...
- "When importing project backups from Allplan 2014 and 2013, you now have the option to convert the data and to import them into a new project. After having upgraded, you can no longer select the 'Hardlock' (dongle) option."
Cela indique qu'il n'est plus possible de sauvegarder un projet pouvant être lu avec une ancienne version ?
Je travail avec des artisans qui sont encore en version 2012, donc ils ne pourront plus ouvrir mes plans (puisqu'ils ont un système Hardlock) ?
Remarquez, je dis ça mais je suis toujours pour l'instant en version 2015...
MessagePosté le: Lun 21 Sep 2015 - 11:57    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
La nouvelle politique Allplan venue d'Allemagne ne me plait absolument pas.
MessagePosté le: Lun 21 Sep 2015 - 12:15    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
.. et je vais attendre encore pour passer a la 2016 ..
MessagePosté le: Mer 21 Oct 2015 - 16:21    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
hello
Hotfix Allplan 2016-0-4 arrivé il y a peu ...enjoy Okay
Release Notes
General
Allplan 2016 is now available as a student version, too.
Setup, licensing, auto-update
You can still work with the IBD wizards after having upgraded from Allplan 2015 to Allplan 2016.
License server: If you do not select the 'Start network server' option in CodeMeter WebAdmin when you select a license server license, the license server service does not start. The system now issues a message to this effect.
We improved auto-update.
Auto-update now installs hotfixes faster.
The administrator in a workgroup environment can allow or forbid users to find and auto-update hotfixes. This setting now works correctly.
Library
Allplan displays smart symbols correctly in the preview of the Library palette even if you change the view for the preview.
Building structure
When you create a new plane model using 'Floor Manager', Allplan keeps the 'Reports' structural level in a building structure you created manually.
We improved the building structure wizard for creating a new building structure.
Basic
Draft
You can enter any values when stretching entities.
Interfaces
When you export exploded data using the ODX interface, Allplan groups the objects correctly.
IFC interface
You can export data to IFC format even though you inadvertently deleted the original data of an advanced XRef you had inserted beforehand.
bim+ interface
We adjusted the links to login and password in 'Export bim+ Data' to the changes in the bim+ platform.
Allplan now exports data to bim+ in the background; so you can continue to work in Allplan. When export is complete, you will get a message or an email with information on the data exported.
We improved export of certain types of data to bim+.
PDF import
We improved the message Allplan displays when you try to import protected PDF files.
Layout
If you have defined a project angle for rotated plan view and you place a layout element, Allplan uses the correct points for drawing and placing layout elements in a congruent manner.
When you change the sequence of layout elements in a layout window, the display sequence in other layout windows does not change.
Architecture
Roofs, Planes, Sections
Allplan no longer issues any messages when you 'Undo' a roof plane above a wall with a window opening and a SmartPart.
Assigning surfaces no longer affects the properties of roof planes.
Allplan automatically updates dimension strings you created with 'Dimension Walls' to reflect any changes you have made to the geometry.
We improved the 'Join Linear Components' and 'Join Linear Component with Line' tools for joining multi-layer walls layer by layer.
A facing in an opening gets the material of the construction layer in which you inserted the facing.
If wizards contain profile walls with 2D symbols being used for the cross-sections, Allplan keeps these cross-sections when you upgrade from Allplan 2015 to Allplan 2016 (the new paths to the symbols are not taken into account here).
You can edit French doors using handles and direct object modification.
Fixtures in walls with absolute elevations can be moved in the z direction.
When you create window SmartParts with tilt-and-turn casements, Allplan tilts the corresponding casement in 3D if 'Position' is set to 'Open'.
When you create blinds as SmartParts, Allplan correctly calculates the 'Offset to opening at top/bottom'.
Presentation
Animation
Allplan correctly displays shadows cast on rotated SmartParts when you set the view type to 'Animation' and select the 'Edges' option.
We improved VRML import. You can now import data containing objects with a very large number of points.
Engineering
Bar Reinforcement
When you change a SmartPart with reinforcement in the SmartParts palette, Allplan keeps the manually created dimensions of the reinforcement.
Allplan exactly snaps to points of dimension lines you created with 'Dimension Line, Label' and the 'Formwork edges' option.
Allplan correctly updates associative reinforcing bar legends after modifications have produced new mark numbers.
We improved the 'Reinforcement schedule - British Standard' ('Shape Code' and 'Total Length').
Associative Views
You can use your own label style to label a slab opening in an associative view.
Switzerland
You can now define display settings separately for each envelope in the tractrix settings.
We improved the performance in CADICS for processing large element groups imported from Allplan.
bco (21/10/15), Dominici Gilles (26/10/15)
Dominici Gilles
MessagePosté le: Mer 25 Nov 2015 - 10:09    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Bonjour, nouvelle mise à jour d'Allplan 2016:
Service Release Allplan 2016-1
Remarques sur la version
Nouveautés importantes :
Généralités
La représentation des éléments dans la couleur de sélection lors du pointage sur l'annotation des éléments avec la souris a été repensée et uniformisée. Le fonctionnement est désormais le suivant : En pointant sur l'annotation à l'aide de la souris, l'élément annoté est représenté dans la couleur de sélection. En pointant sur l'élément lui-même, les éléments associés (par exemple l'annotation) sont également marqués. Les groupes d'éléments constituent un cas particulier car leurs éléments constitutifs peuvent être modifiés ou supprimés (par exemple groupes de pièces). En pointant sur l'annotation du groupe, tous les éléments constitutifs ainsi que leur annotation sont marqués. Les éléments constitutifs individuels se comportent comme les éléments annotés normalement, à l'instar des groupes d'éléments dont les éléments constitutifs peuvent être modifiés.
Bibliothèque
La recherche dans la palette "Bibliothèque" permet non seulement de trouver des éléments de bibliothèques mais aussi des dossiers. La recherche est également effectuée dans un chemin externe défini au préalable.
Dans la palette "Bibliothèque", si vous sélectionnez un chemin externe vers un dossier de bibliothèque d'une version antérieure d'Allplan installée en parallèle, vous pouvez désormais définir si les éléments de bibliothèque doivent rester disponibles dans la version antérieure. Un message s'affiche pour vous le demander.
Lors de l'enregistrement des éléments de bibliothèque, vous pouvez désormais remplacer les entrées existantes. Les éléments pouvant être remplacés dépendent du type d'élément qui doit être enregistré : les fichiers de symboles remplacent les symboles, macros et SmartParts, les macros remplacent les macros et SmartParts, les SmartParts remplacent uniquement les SmartParts.
Les symboles de statique placés dans le dossier "Symboles et pictogrammes" dans les versions antérieures se trouvent désormais par défaut dans le dossier Objets 2D d'Allplan 2016-1.
Le mobilier de salle de bains dans le dossier "Meubles" - "Salle de bains/WC" a été enrichi, les miroirs et lavabos sont à nouveau inclus.
Les profilés en acier U 2D, UPE 2D et Z 2D jusqu'ici disponibles en double dans la bibliothèque se trouvent désormais dans le dossier "Objets 2D" - "Coupe de profilés en acier".
Explorateur d'objets
Les critères de tri définis par l'utilisateur dans la palette "Objets" peuvent désormais être enregistrés comme favoris et réutilisés. Dès que vous ouvrez le tri défini par l'utilisateur dans le champ de liste supérieur, les symboles connus s'affichent à droite.
Modélisation 3D
Les volumes 3D polygonaux concernés ont été simplifiés pour le calcul des opérations booléennes afin de l'accélérer.
Le chargement des calques contenant de nombreux éléments 3D avec courbes généraux complexes est également accéléré. Cela est notamment visible lorsque vous changez de vue ou que vous modifiez la taille de la fenêtre.
Les points d'intersection réels et virtuels des volumes et surfaces 3D généraux ainsi que des éléments polygonaux 3D peuvent désormais être affichés et utilisés pour dessiner d'autres éléments.
Interface de programmation Python
Allplan 2016-1 comprend une version beta de la future interface de programmation (API) Pyton à partir de laquelle il est possible de créer des modèles 3D avec ferraillage. Pour accéder aux exemples, configurez le chemin externe ETC\EXAMPLES dans la bibliothèque.
Généralités
Le traitement et la résolution de différents messages issus du Quality Reporter ont permis d'améliorer la stabilité d'Allplan.
Installation et licence
L'installation silencieuse n'affiche pas les boîtes de dialogue des composants qui ne proviennent pas d'Allplan.
La procédure d'attribution de licence WIBU d'Allplan a été améliorée sur plusieurs points.
L'aide concernant la restitution de licence en cas d'activation hors ligne a été étendue.
Les fichiers journaux du gestionnaire de licence sont désormais enregistrés dans un dossier propre sous TEMP.
Workgroup, Workgroup Online
Allplan Workgroup Online peut désormais être utilisé avec une version récente de FileZilla (à partir de la version 0.9.43).
Les projets peuvent à nouveau être déplacés depuis Workgroup Server vers Workgroup Online Server.
Structure du bâtiment
La sélection actuelle dans la structure du bâtiment peut être enregistrée dans les favoris et réutilisée.
Dans les informations dérivées de la structure du bâtiment, vous retrouverez le niveau de structure "Rapports", même lorsque vous créez manuellement une structure de bâtiment.
Si les calques en tant que calques sources ont été sélectionnés dans les informations dérivées de la structure du bâtiment, cette assignation est désormais conservée lorsque vous ouvrez à nouveau la structure du bâtiment sans gestionnaire de groupes de travail.
Bibliothèque
La navigation dans la bibliothèque a été améliorée : dans la zone de navigation, le bouton "Retour" permet de remonter d'un niveau hiérarchique.
Le nom des dossiers créés dans la bibliothèque ne peuvent contenir que des caractères autorisés ; un message correspondant vous en avertit.
Bases
Lors de la création d'un projet basé sur un modèle de projet, les chemins de ressources sont définis par défaut sur "Projet". Les ressources de projet sont désormais incluses dans le modèle de projet.
Pour l'annotation des composants, éléments ou coupe, la couleur d'arrière-plan n'est plus reprise par défaut à partir des derniers paramètres texte actifs. Si vous souhaitez une couleur d'arrière-plan, vous pouvez la sélectionner après activation de l'annotation dans la palette "Propriétés".
A l'aide des commandes "Modifier" et "Pivoter", l'angle correct des éléments à poignées s'affiche dans la boîte de dialogue des coordonnées.
Tous les types de points peuvent être analysés, par exemple dans les rapports, légendes ou styles d'annotation.
Dessin
La fonction "Nuage de révision" permet de fixer le motif linéaire correspondant. Par conséquent, la fonction "Propriété de motif linéaire" est désormais bloquée lors de la modélisation d'un nuage de révision.
Mise en page de plans
Les plans avec vues associatives sont chargés plus rapidement.
En modifiant le contour d'une fenêtre de plan à l'aide de la fonction "Briser une ligne", le contour d'origine n'est plus visible.
Interfaces
Interface DWG
L'importation de fichiers DWG avec des volumes 3D généraux (BReps) dans Allplan a été améliorée.
L'importation de certaines données DWG peuvent provoquer des incohérences, notamment lorsque des ellipses et des cercles sont exclus de l'importation. Ces incohérences ne se produisent plus.
Interface IFC
Les barres exportées depuis Allplan au format IFC sont désormais correctement réimportées dans Allplan.
Interface bim+
Le symbole "exporter les données bim+" a été adaptée pour correspondre à l'apparence de la plateforme bim+.
Les couleurs du ferraillage restent inchangées lors de l'exportation vers bim+.
Le téléchargement de données Allplan vers bim+ a été amélioré, le message s'affichant sans motif a été supprimé.
Exportation PDF
L'exportation d'éléments avec hachurages et motifs complexes en PDF a été améliorée.
iTWO, CPIXML
La fonction "Exporter les données iTWO..." a été renommée "Exporter les données CPIXML..." pour correspondre au format de fichier des données exportées.
Architecture
Murs, ouvertures, éléments de construction
Des paramètres supplémentaires sont disponibles pour les commandes "Porte, SmartPart Porte et portail" - "Porte sectionnelle" : Le renvoi peut être modifié, un cadre de montage (facultatif) peut également être défini, il est possible d'appliquer du verre à un ou à tous les panneaux.
Les modifications des paramètres pour les lamelles et rails de volets roulants (créés avec la fonction "SmartPart - Brise-soleil") s'appliquent désormais à la vue en plan 2D.
Pièces, surfaces, étages
Les légendes peuvent être uniquement créées à partir des composants d'architecture et d'ingénierie.
Modules supplémentaires
Modélisation 3D
Le menu contextuel des éléments 3D généraux (avec courbes) comprend désormais la fonction "Convertir les éléments".
La représentation filaire des éléments 3D généraux comme les cercles et les arcs est désormais possible.
La commande "Loft" a été améliorée par l'ajout de l'option "Option de sélection pour les éléments ambigus" pour les contours superposés dans la vue en plan.
La fonction "K1 moins K2, supprimer K2" peut désormais être utilisée pour les volumes spéciaux et complexes.
Terrain
Plan de situation
Le paramètre d'annotation "Tp-A/J" (taille de la police) est à nouveau pris en compte pour l'annotation des jonctions d'éléments.
Ingénierie
Vues associatives
Le texte supplémentaire créé à l'aide de la commande "Modifier le texte" dans l'annotation d'une vue associative est conservé après une modification comme le nom de la coupe.
La modification du volume de coupe d'une vue associative avec poignées a été améliorée.
Le comportement en cas d'atteinte du nombre maximal de documents références a été amélioré.
Ferraillage de barres d'armature
L'annotation de schéma et de cadres dans certains types de polices est conservée de manière correcte après modification directe des barres.
Le schéma global est conservé de manière correcte après la modification directe d'une barre à l'aide de la commande "Modifier les points".
La fonction "Informations élément" - "Contrôle des pièces pour les schémas partiels et globaux" se comporte comme dans la version antérieure : Seules les barres d'armature sans schéma partiel ou global sont représentées. L'armature enregistrée dans la bibliothèque en tant que symbole comprenant des barres, une vue associative, la cotation et l'annotation des schémas peut à nouveau être positionnée et modifiée sans limitations grâce à la modification d'objet directe.
L'analyse des formes de barres réparties dans des zones polygonales dans des légendes et rapports a été améliorée. L'impression est identique aux tableaux de schéma.
Afin de prendre en charge la méthode BIM et d'assurer une visualisation optimale des cages d'armature, vous disposez désormais de la possibilité de modifier les propriétés de format des éléments 3D correspondants, outre les options d'animation "Plume, trait, couleur des layers" et "Couleurs d'aspect de surface depuis diamètres" dont vous disposiez jusqu'à présent.
La réattribution des barres lfdm a été améliorée.
Ferraillage des treillis
La modification et la suppression des formes de panneaux a été améliorée.
La boîte de dialogue "Polygonisation des éléments" ouverte via "Convertir des éléments" - "Elément 3D général en volume/surface 3D" s'adapte automatiquement à la longueur du texte de la langue correspondante.
British Standard
La longueur globale des barres avec un angle de 180° apparaît désormais de manière correcte dans le rapport "Liste barres British Standard".
Angleterre
Le contenu du dossier "Inserts" a été amélioré et actualisé.
Japon
La localisation des palettes des différents SmartParts a été améliorée.
Aperçu remarques sur la version
Gilles
Les membres suivants remercient Dominici Gilles pour ce message :
Lemmy (25/11/15), paupiette22 (25/11/15), Karl-alexandre (25/11/15)
MessagePosté le: Mer 25 Nov 2015 - 10:43    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Je télécharge Smile merci pour l'info
MessagePosté le: Mer 25 Nov 2015 - 10:59    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Shocked Shocked Shocked
Citation:
il faut que je regarde ça moi !!
MessagePosté le: Mer 25 Nov 2015 - 11:12    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
ca va faire des Higher Faster Smarter parts ...
MessagePosté le: Mer 25 Nov 2015 - 11:27    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
je sais pas mais ça deviens intéressant niveau programmation .. si c'est comme C4D on pourra peu être faire des plugs dans Allplan .. à voir
MessagePosté le: Mer 25 Nov 2015 - 12:09    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Je crois que c'est le but...
Mais comme toujours, regardons avant de crier victoire... Wink
MessagePosté le: Mer 25 Nov 2015 - 12:16    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
c'est clair ..comme saint thomas ...je suis .. Mr. Green
MessagePosté le: Mer 25 Nov 2015 - 13:28    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
tu bois jamais d'eau ?
hccomp
MessagePosté le: Mer 25 Nov 2015 - 13:52    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Mise à jour plante chez moi.
La mise à jour n'est pas dispo sur Connect.
MessagePosté le: Mer 25 Nov 2015 - 14:05    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
ce matin elle y était ... pourquoi ils l'ont enlevée ? ...
MessagePosté le: Mer 25 Nov 2015 - 15:00    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Oui, elle n'y est plus... Sad
MessagePosté le: Aujourd’hui à 02:00    Sujet du message: Mises à jour Allplan 2016
Page 2 sur 8
