Mises à jour Allplan 2016
Aller à la page: 1, 2, 3, 4, 5, 6, 7, 8  >
MessagePosté le: Mar 7 Juil 2015 - 08:30    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Release Allplan 2016
Release Notes
General
The maximum document size you can define using the 'docsize' hotline tool is now 1 GB.
Setup and Licensing
New licensing system by Product Key
Improved import of individual drawing files from a project backup
Better data handling when auto-updating future service releases
Improved administration of user attributes with certain international licenses
Improved messages when auto-updating
Improved installation using auto-update after restart of computer
Library palette
Flat hierarchy: you can save all types of library elements (symbol, smart symbol, SmartPart) to a single folder.
Libraries in all paths (default, project, private and office) have flat hierarchies.
Symbols and smart symbols are saved as single files in SYM format and NMK format, respectively.
Symbols in ZSY symbol catalog files of earlier versions were separated into single symbol files in SYM format.
Smart symbols in OM* smart symbol catalog files of earlier versions were separated into single smart symbol files in NMK format.
You can save symbols and smart symbols with resources.
The basic tools - create, rename, copy, paste and delete - are now consistent.
The 'text symbol' hierarchical level is no longer available; text symbols from earlier versions are converted to symbols.
Small icons and symbols help you identity library elements quickly and easily in the palette.
ToolTips include the element type and date of creation.
We added functionality to the filter in the library: you can now show and hide symbols, SmartParts and smart symbols separately.
After the upgrade, the external paths defined in earlier versions are predefined.
We redeveloped localization of symbols in the default path.
We also redeveloped symbol selection for tools allowing you to use a symbol for the outline, for example, the 'Column' tool.
Empty folders are automatically hidden when you use a tool with a prefiltered selection of library elements.
You can search in all libraries (starting in the folder where you start searching).
Allplan saves symbol catalog files and smart symbol catalog files of earlier versions as BAK files to the TEMP folder before it separates them into single symbol files and smart symbol files, respectively.
After the upgrade, Allplan combines the contents of folders with the same name in a single folder.
You can find a new info button for the font size in the library palette.
Using the shortcut menu, you can open certain folders straight in Windows Explorer (except folders in the default path).
Tools using library elements present only appropriate elements for selection. For example, the 'Window' tool lets you select only smart symbols and SmartParts.
We adapted text of special smart symbol functions for use in the library palette.
Symbol names can be longer than 32 characters in the library palette.
Using cut and paste, you can move library elements and folders in the library palette.
Multiple selection of library elements
You can sort library elements alphabetically in ascending or descending order.
You can sort library elements by date in ascending or descending order.
You can hide empty folders.
Improved options dialog box
Multiple selection of folders in the library palette
If the path of a group or folder is too long, Allplan issues a warning.
While searching, you can enter additional letters, thus narrowing down the choice.
You can no longer manage symbols and smart symbols in ProjectPilot.
You can sort folders.
You can no longer select the language for default symbols in the Services application. Allplan automatically adjusts the symbol names when you switch to a different language.
While searching, Allplan does not display the full path names.
More new features
All elements in the default path are stored in the ETC folder; you can no longer find them in STD\SYM.
After the upgrade, Allplan saves symbols and SmartParts to special folders.
You can create as many subfolders as you need.
The path must not be longer than 180 characters.
You cannot use the following characters in names of library elements and folders:
- / \ : “ ? *> < l "
Object navigator
The new objects palette (object navigator) lists all elements and objects in all currently selected drawing files (current, edit mode, reference mode).
You can control visibility with one click. For example, you can invert selection, show or hide selected objects or all objects and activate or deactivate all objects.
The new objects palette lets you zoom in on objects in the workspace.
Four sorting criteria are predefined: sort by building structure, sort by drawing file, sort by layer and sort by material.
In addition to selecting a sorting criterion, you can customize the sort sequence.
You can group the objects according to the structural levels of the building structure; you can also sort them alphabetically.
You can group the objects by drawing file; you can also sort them alphabetically. If you want, you can change the drawing file status.
You can group the objects by layer and sort them alphabetically: you can change the layer status and visibility.
You can change or re-assign layers in the list by dragging them to another layer group. As an alternative, you can also select cut and paste on the shortcut menu.
You can group the objects by material and sort them alphabetically; objects without materials are assigned to a special group.
You can change or re-assign materials in the list by dragging them to another material group. As an alternative, you can also select cut and paste on the shortcut menu.
Viewports
You can float viewports independently of the Allplan application window. You can even drag them to a second monitor.
You can float viewports with free NDWs independently of the Allplan application window. You can even drag them to a second monitor.
You can dock viewports to the Allplan application window.
You can dock viewports with free NDWs to the Allplan application window.
Interfaces
ODX interface
Custom XRefs are displayed in the preview (DXF, DWG).
You can display exported data as preview bitmaps.
We improved export of smart symbols containing 3D objects and fills.
We improved export of dimension strings to DGN format.
The 'Check file during import' option is active by default.
You can export DGN files containing MicroStation color tables.
Allplan does not create element groups when you import a DWG file with the 'Arrange layers' setting set to 'Documents'.
Allplan always uses the correct text size to import attributes defined for an element in a DWG file.
Allplan always imports BMP files, regardless of how long the name of the DWG file is.
We improved export of mirrored circles and ellipses when you use exchange favorite 1.
You can export hidden layers using the 'Export hidden layers' option.
We improved DWG export of certain documents containing exploded patterns.
Allplan includes underlined text when you export data in exploded manner to DWG (using exchange favorite 1, for example).
Allplan takes into account the resizing factor when you export data to DGN (using exchange favorite 1, for example).
Allplan correctly transfers scale-independent text (for example, in legends).
Allplan correctly transfers label styles with borders to DWG format.
We expanded the dropdown list for selecting exchange favorite.
Smart door symbols you export as 2D data get Z coordinates with the value 0.
Allplan correctly exports the text size of attributes to DGN format.
After importing data with offset coordinates, Allplan displays all elements in their entirety.
Allplan creates an element group from exploded elements during DGN export (similar to DXF/DWG export).
Allplan correctly transfers arrowheads and extension lines to DGN format.
When Allplan detects large coordinates during DXF/DWG import, it displays a dialog box for adjusting the coordinates.
IFC interface
Allplan includes 3D solids with the 'IFC object type' = 'IfcSite' attribute when exporting data to IFC.
Allplan transfers all attributes when exporting multi-layer walls to IFC.
IFC files with special characters in their names get the correct file name in the file header.
Allplan includes openings in walls with the 'IFCCURTAINWALL' IFC Object Type when exporting data to IFC.
We improved IFC export of openings under curved planes.
We improved IFC import of beams with the 'Import IFC Data' tool.
When importing certain IFCXML files with openings, Allplan checks and corrects the extruded opening objects.
We improved IFC export of walls with multiple surfaces.
3D Modeling
The world's leading PARASOLID modeling kernel by Siemens was integrated in Allplan 2016.
New objects: 3D circle and 3D arc.
New object: 3D spline.
You can modify 3D circles and 3D arcs using handles and data entry boxes.
You can modify 3D splines using handles.
You can modify 3D circles and 3D arcs using the properties palette.
You can modify 3D splines using the properties palette.
Spheres are now delimited by curves.
Cylinders are now delimited by curves.
You can modify spheres using handles and data entry boxes.
You can modify cylinders using handles and data entry boxes.
New objects: general 3D object, general 3D surface.
Properties palette for the new objects: general 3D object, general 3D surface
'Extrude' tool with a preview of the work plane
'Extrude' tool with a new option to create new elements
Using 'Extrude', you can extrude a planar surface from a curved element.
New 'Modify Edge Offset' tool for polygonal 3D solids and 3D surfaces
New 'Rotate' tool
New 'Extrude Along Path' tool
New 'Loft' tool
New 'Sweep Path' tool
New 'Chamfer Edge' tool
New 'Fillet Edge' tool
We improved the 'Parallel Lines' tool for 3D lines and 3D curves.
Using the 'Combine Lines to Make Polylines' tool, you can now edit 3D lines.
Using the 'Split Polylines into Discrete Lines' tool, you can now edit 3D lines.
Using the 'Intersect 2 Entities' tool, you can now edit 3D lines.
Using the 'Chamfer' tool, you can now edit 3D lines.
Using the 'Fillet' tool, you can now edit 3D lines and 3D curves.
We expanded the element filter to include the new elements: 3D circle, 3D arc, 3D spline, general 3D object, general 3D surface.
Using the 'Convert Elements' tool, you can convert 3D circles, 3D arcs and 3D splines to polygons.
Using the 'Convert Elements' tool, you can polygonize general 3D objects and general 3D surfaces.
You can convert 2D circles and 2D arcs to 3D.
You can convert 2D splines to 3D.
You can apply the 'Slice' tool to 3D lines, 3D polygons, 3D circles, 3D arcs and 3D splines.
You can apply the 'Slice' tool to general 3D objects and general 3D surfaces.
You can assign attributes to 3D circles and 3D splines.
You can edit 3D elements with curves using Boolean functions.
3D elements with curves are visible in associative views and sections.
3D elements with curves are visible in architectural sections and hidden line images.
Using 'Change Archit. Properties', you can assign architectural attributes, such as surface elements, trade and material, to general 3D objects and general 3D surfaces.
Smart symbols can contain general 3D objects and general 3D surfaces.
Element groups can contain general 3D objects and general 3D surfaces.
You can export general 3D objects and general 3D surfaces to CINEMA 4D.
You can export general 3D objects and general 3D surfaces to 3D PDF.
Allplan exports 3D circles and 3D arcs as curves to Rhino.
Allplan exports 3D splines as curves to Rhino.
Allplan imports 3D circles and 3D arcs as curves from Rhino.
Allplan imports 3D splines as curves from Rhino.
Allplan exports 3D circles as curves to CINEMA 4D.
Allplan exports 3D splines as curves to CINEMA 4D.
Allplan imports 3D circles and 3D arcs as curves from CINEMA 4D.
Allplan imports 3D circles and 3D arcs as curves from Autocad (Allplan c'est mieux) (Allplan c'est mieux) (Allplan c'est mieux).
Allplan imports 3D splines as curves from Autocad (Allplan c'est mieux) (Allplan c'est mieux) (Allplan c'est mieux).
Architecture
General improvements
The 'Filter Assistant' toolbar provides the new 'Filter by fill' element filter for fills with gradients.
The shortcut menus of the 'Room group' and 'Story' elements offer the 'Modify group of rooms or stories' and 'Label group of rooms or stories' modification tools.
We revised the dialog box for 'Replace Smart Symbol, SmartPart': you can now find clear descriptions for the different options.
The 'Smart Window and Door Symbols' tool will no longer be available in future versions. Therefore, Allplan issues a message to this effect when you open this tool.
SmartParts
Using the 'Roller shutters' option, you can now define the position of roller shutters for window SmartParts and door SmartParts. You can thus set rails and housings.
You can choose from new casement types for window SmartParts. For example, you can create bottom hung windows.
You can choose from new fittings for door SmartParts: 'door handle with rosette' and 'door knob with rosette'.
Panic hardware is now available for door SmartParts.
You can define the distance between the window handle and the lower frame separately for each side. This is important for barrier-free building.
You can define the distance between the door handle and the bottom frame separately for each side.
You can define the distance between the grab bar and the bottom level of the door leaf separately for each side. This is important for planning escape routes.
You can select style areas in addition to hatching, patterns and fills for displaying windows and doors in sections. You can make different settings for 2D and 3D.
You can select style areas in addition to hatching, patterns and fills for displaying roller shutters in sections. This is only possible for 3D.
Using the settings for SmartParts, you can define how to display a SmartPart placed in a sloping plane. You can choose between 2D representation and 3D representation. When you choose the latter, the 3D representation of the SmartPart is projected to plan view (as usual in Allplan).
Improved icons for window sills and fittings.
Improved icons for door handles.
Improved icon for the 'Shading SmartPart' tool.
You can model lifting doors using the 'Door SmartPart' tool.
You can find the new 'Skylight SmartPart' tool in the 'General: Roofs, Planes, Sections' module.
When you save SmartParts to the library, Allplan automatically creates a preview of the object in isometric view.
The 'Shading SmartPart' - 'Blinds' tool offers more types.
The 'Door SmartPart' - 'Lifting door' tool offers more types.
The 'Skylight SmartPart' tool offers more types.
The 'Transfer SmartPart Version' tool, which converts SmartParts from earlier versions, converts SmartParts belonging to an element group.
You can use the PIPE command in the SmartPart Editor.
Presentation
Allplan 2016 uses the CineRender R15 render engine.
When rendering with CineRender, you can use the 'Ambient occlusion' rendering method with various settings.
Using the 'Merge' or 'Add' tool in CINEMA 4D, you can update your Allplan model.
When rendering with CineRender, Allplan correctly processes certain bitmap formats.
Allplan internally uses the 'Photometric intensity' option for rendering all types of light. This produces realistic result, in particular, when you use the 'Area' light type for indoor lighting.
The 'RTRender' view type offers the new, easy-to-use 'White model' setting for paper models.
When you select the 'Quality' stop criterion for the 'RTRender' view type, Allplan shows the progress as a percentage (instead of a time indicator). The percentage indicator is more precise.
When you interrupt the 'RTRender' calculation, Allplan will indicate this at the bottom of the viewport.
Problems with displaying superimposed transparent objects in animation were eliminated by OpenGL 4.2 in conjunction with nVidia graphics cards and the current driver. (You can now superimpose up to 32 layers.)
Smooth movement: if Allplan cannot achieve the refresh rate set, if reduces the display quality of the model.
You can now drag textures straight from the browser to the 'Surfaces' palette. Similarly, you can drag bitmaps straight from the browser to the 'Surroundings' palette.
When using drag-and-drop operations for textures, Allplan marks the possible target buttons in the 'Surfaces' palette.
When you create and save a texture in the office folder, Allplan automatically copies it to the current project.
You can copy and paste individual project lights or all project lights.
When changing lights, you can also snap to the corners of area lights.
You can change the properties of several lights in a single step.
The 'Camera path' palette updates automatically to reflect the cameras you are defining using the 'Set Camera Path' tool.
When you retain the file name in the 'Record Movie' tool, Allplan issues a message asking whether you want to overwrite the movie.
We improved precision for drawing the start points and end points of large arcs and splines.
We sped up the update of complex associative sections in certain cases (section of entire model, 3D smart symbols).
The 'Sketch' and 'Hidden' view types display the new 3D elements (polygonal or with curves).
The settings you make for hidden edges in the 'View type' palette for 'Animation' also apply to the new 3D elements.
Using the 'Options' - 'Rooms', you can specify whether you want to display finish elements in all view types or in shaded view types only (hidden, animation).
All shaded view types (hidden, animation, sketch) display selected elements in the selection color.
Visualization of complex 3D elements with arcs and curves is not blocked by tessellation; Allplan increases the quality step by step.
Using the 'Movie Model' tool ('File' menu - 'Import'), you can import and use movie models saved as *.FIL files in earlier versions.
Engineering
Section Along Curve
You can show or hide drawing files and elements using a filter.
Allplan retains the position of the section when you hide elements.
You can create a frozen or associative representation of the section. Only the section is linked with the model.
You can also this tool to the new general 3D elements, too.
We added functionality to the shortcut menu of 'Section Along Curve'.
You can use the new 'Dimension Section' tool to dimension sections. You can find this new tool in the 'Bridge and Civil Engineering' module and on the shortcut menu.
Import LandXML Data
Using the 'Import LandXML Data' tool ('File' menu - 'Import'), you can import 3D terrain points and route location lines.
Allplan imports route location lines as composite elements.
An unnamed drawing file gets the name of the file.
BIM reinforcement attributes
Using object manager, you can assign any attributes to reinforcing bars and meshes placed, such a material, production as precast element or on site, construction stage and so on.
Allplan takes these attributes into account when exporting and importing IFC data.
You cannot assign attributes to reinforcement placed in SmartParts.
We adjusted general and engineering-specific modification tools.
We added functionality to the shortcut menu of reinforcement elements.
Structural Analysis View
You can find the new 'Structural Analysis View' export option in the settings for IFC export.
Allplan exports the following elements: column, downstand beam, upstand beam, slab, panel, wall.
You can create a report of exported elements.
You can export openings in walls, slabs and panels
MessagePosté le: Mar 7 Juil 2015 - 08:30    Sujet du message: Publicité
MessagePosté le: Mar 21 Juil 2015 - 11:25    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Google Traduction
Citation:
Notes De Version
Général
Nous avons édité et corrigé divers messages de qualité Reporter, résultant dans une plus stable Allplan.
La taille maximale du document, vous pouvez définir en utilisant l'outil de hotline »de docsize 'est maintenant de 1 Go.
Installation et licences
Nouveau système de licence par clé de produit
Amélioration de l'importation de fichiers de dessin individuels à partir d'une sauvegarde de projet
La gestion améliorée des données lors de services futures versions de mise à jour automatique
Amélioration de l'administration des attributs de l'utilisateur avec certaines licences internationales
Amélioration des messages lorsque l'auto-mise à jour
Amélioration de l'installation à l'aide d'auto-mise à jour après le redémarrage de l'ordinateur
Palette Bibliothèque
Hiérarchie plat: vous pouvez enregistrer tous les types d'éléments de bibliothèque (symbole, symbole intelligent, SmartPart) pour un seul dossier.
Bibliothèques tous les chemins (par défaut, projet, privé et social) ont hiérarchies plates.
Symboles et symboles intelligents sont enregistrées sous forme de fichiers unique, au format SYM et le format NMK, respectivement.
Symboles dans ZSY fichiers du catalogue de symbole de versions antérieures ont été séparés en fichiers de symboles simples au format SYM.
Symboles intelligents dans OM fichiers * intelligents catalogue symbole de versions antérieures ont été séparés en fichiers de symboles intelligents simples au format NMK.
Vous pouvez enregistrer des symboles et des symboles intelligents avec des ressources.
Les outils de base - créer, renommer, copier, coller et supprimer - sont désormais conformes.
Le niveau hiérarchique 'symbole de texte' est plus disponible; symboles de texte à partir de versions antérieures sont converties en symboles.
Petites icônes et symboles vous aident, des éléments de la bibliothèque de l'identité rapidement et facilement dans la palette.
Les info-bulles sont le type et la date de la création de l'élément.
Nous avons ajouté des fonctionnalités pour le filtre dans la bibliothèque: vous pouvez maintenant afficher et masquer les symboles, SmartParts et symboles intelligents séparément.
Après la mise à niveau, les chemins externes définies dans les versions antérieures sont prédéfinis.
Nous avons réorganisé la localisation de symboles dans le chemin par défaut.
Nous avons également réaménagé sélection de symbole pour les outils vous permettant d'utiliser un symbole pour le contour, par exemple, l'outil «Colonne».
Les dossiers vides sont automatiquement masquées lorsque vous utilisez un outil avec une sélection préfiltrée d'éléments de bibliothèque.
Vous pouvez effectuer une recherche dans toutes les bibliothèques (à partir dans le dossier où vous commencez à la recherche).
Allplan enregistre symbole fichiers et fichiers de catalogue intelligents catalogue symbole de versions antérieures que les fichiers BAK dans le dossier TEMP avant qu'il ne les sépare en fichiers de symboles simples et fichiers de symboles intelligents, respectivement.
Après la mise à niveau, Allplan combine le contenu des dossiers portant le même nom dans un seul dossier.
Vous pouvez trouver un nouveau bouton info pour la taille de la police dans la bibliothèque palette.
En utilisant le menu contextuel, vous pouvez ouvrir certains dossiers directement dans l'Explorateur Windows (à l'exception des dossiers dans le chemin par défaut).
Outils utilisant des éléments de bibliothèque présentent seuls éléments appropriés pour la sélection. Par exemple, l'outil "Fenêtre" vous permet de sélectionner uniquement des symboles intelligents et SmartParts.
Nous avons adapté le texte de fonctions de symboles intelligents spéciales pour une utilisation dans la bibliothèque palette.
Les noms de symboles peuvent être plus de 32 caractères dans la bibliothèque palette.
Utiliser couper et coller, vous pouvez déplacer des éléments et des dossiers de la bibliothèque dans la bibliothèque palette.
La sélection multiple d'éléments de bibliothèque
Vous pouvez trier les éléments de la bibliothèque par ordre alphabétique dans l'ordre croissant ou décroissant.
Vous pouvez trier les éléments de la bibliothèque par date en ordre croissant ou décroissant.
Vous pouvez cacher les dossiers vides.
Boîte de dialogue des options améliorées
Sélection de plusieurs dossiers dans la palette bibliothèque
Si le chemin d'un groupe ou d'un dossier est trop long, Allplan émet un avertissement.
Pendant la recherche, vous pouvez saisir des caractères supplémentaires, réduisant ainsi le choix vers le bas.
Vous ne pouvez plus gérer les symboles et les symboles intelligents Pilote de projets.
Vous pouvez trier les dossiers.
Vous ne pouvez plus sélectionner la langue des symboles par défaut dans l'application Services. Allplan ajuste automatiquement les noms de symboles lorsque vous passez à une autre langue.
Pendant la recherche, Allplan ne présente pas les noms de chemin complet.
Plus de nouvelles fonctionnalités
Tous les éléments dans le chemin par défaut sont stockés dans le dossier de l'ETC; vous ne pouvez plus les trouver dans STD \ SYM.
Après la mise à niveau, Allplan enregistre symboles et SmartParts à des dossiers spéciaux.
Vous pouvez créer autant de sous-dossiers que vous avez besoin.
Le chemin ne doit pas être plus long que 180 caractères.
Vous ne pouvez pas utiliser les caractères suivants dans les noms des éléments et des dossiers de la bibliothèque:
- / \: "? *> <L "
Object Navigator
La nouvelle palette d'objets (Object Navigator) répertorie tous les éléments et objets de tous les fichiers de dessin sélectionnées (courant, le mode d'édition, le mode de référence).
Vous pouvez contrôler la visibilité en un seul clic. Par exemple, vous pouvez inverser la sélection, afficher ou masquer les objets sélectionnés ou tous les objets et activer ou désactiver tous les objets.
La nouvelle palette d'objets vous permet de zoomer sur des objets dans l'espace de travail.
Quatre critères de tri sont prédéfinis: trier par la structure du bâtiment, trier par fichier de dessin, trier par couche et trier par matériau.
En plus de choisir un critère de tri, vous pouvez personnaliser la séquence de tri.
Vous pouvez regrouper les objets en fonction des niveaux de structure de la structure du bâtiment; vous pouvez également trier par ordre alphabétique.
Vous pouvez regrouper les objets par fichier de dessin; vous pouvez également trier par ordre alphabétique. Si vous voulez, vous pouvez changer le statut de fichier de dessin.
Vous pouvez regrouper les objets par couche et les trier par ordre alphabétique: vous pouvez modifier l'état de la couche et la visibilité.
Vous pouvez modifier ou réaffecter couches dans la liste en les faisant glisser à un autre groupe de calques. Comme alternative, vous pouvez également sélectionner couper et coller dans le menu contextuel.
Vous pouvez grouper les objets selon la matière et de les trier par ordre alphabétique; objets sans matériaux sont affectés à un groupe spécial.
Vous pouvez modifier ou réaffecter des matériaux dans la liste en les faisant glisser à un autre groupe de matériaux. Comme alternative, vous pouvez également sélectionner couper et coller dans le menu contextuel.
Fenêtres
Vous pouvez faire flotter les fenêtres indépendamment de la fenêtre de l'application Allplan. Vous pouvez même les faire glisser vers un deuxième moniteur.
Vous pouvez faire flotter les fenêtres avec NDWs gratuits indépendamment de la fenêtre de l'application Allplan. Vous pouvez même les faire glisser vers un deuxième moniteur.
Vous pouvez ancrer les fenêtres de la fenêtre d'application Allplan.
Vous pouvez ancrer les fenêtres avec NDWs gratuits vers la fenêtre d'application Allplan.
Interfaces
Interface ODX
XRefs personnalisés ne sont affichés dans l'aperçu (DXF, DWG).
Vous pouvez afficher les données exportées comme bitmaps aperçu.
Nous avons amélioré l'exportation de symboles intelligents contenant des objets 3D et des remplissages.
Nous avons amélioré l'exportation de chaînes de dimension au format DGN.
L'option «Vérifier fichier lors de l'importation" est active par défaut.
Vous pouvez exporter des fichiers DGN contenant les tables de couleurs de MicroStation.
Allplan ne crée pas de groupes d'éléments lorsque vous importez un fichier DWG avec le paramètre «Organiser les couches de mettre à« Documents ».
Allplan utilise toujours la taille de texte correct pour importer des attributs définis pour un élément dans un fichier DWG.
Allplan importe toujours les fichiers BMP, indépendamment de combien de temps le nom du fichier DWG est.
Nous avons amélioré l'exportation des cercles et des ellipses lorsque vous utilisez Exchange préférée 1 miroir.
Vous pouvez exporter les calques masqués à l'aide de l'option 'couches cachées à l'exportation du.
Nous avons amélioré DWG exportation de certains documents contenant des motifs éclatées.
Allplan comprend le texte souligné lorsque vous exportez des données de manière éclatée au format DWG (en utilisant l'échange préférée 1, par exemple).
Allplan prend en compte le facteur de redimensionnement lorsque vous exportez des données vers DGN (en utilisant l'échange préférée 1, par exemple).
Allplan transfère correctement le texte d'échelle indépendante (par exemple, dans les légendes).
Allplan transfère correctement styles d'étiquettes avec des frontières au format DWG.
Nous avons élargi la liste déroulante pour sélectionner échange préférée.
Symboles de porte intelligentes que vous exportez des données 2D obtiennent Z coordonne avec la valeur 0.
Allplan exporte correctement la taille du texte des attributs au format DGN.
Après l'importation de données avec des coordonnées décalées, Allplan affiche tous les éléments dans leur intégralité.
Allplan crée un groupe d'éléments à partir d'éléments explosé pendant l'exportation DGN (similaire à DXF / DWG exportation).
Allplan transfère correctement pointes de flèches et des lignes d'extension au format DGN.
Lorsque Allplan détecte grandes coordonnées lors de DXF / DWG importation, il affiche une boîte de dialogue pour ajuster les coordonnées.
Interface IFC
Allplan comprend solides 3D avec la SFI type d'objet 'd'attribut =' IfcSite 'lors de l'exportation des données au format IFC.
Allplan transfère tous les attributs lors de l'exportation parois multicouches à la SFI.
Fichiers IFC avec des caractères spéciaux dans leurs noms obtenir le nom de fichier correct dans l'entête du fichier.
Allplan comprend des ouvertures dans les murs avec le 'IFCCURTAINWALL' Type IFC d'objets lors de l'exportation de données à la SFI.
Nous avons amélioré la SFI exportation de l'ouverture sous les plans incurvés.
Nous avons amélioré la SFI importation de poutres avec l'outil 'importation IFC données'.
Lors de l'importation de certains fichiers IFCXML avec des ouvertures, les chèques Allplan et corrige les objets d'ouverture extrudés.
Nous avons amélioré la SFI exportation de murs avec des surfaces multiples.
Modélisation 3D
Leader PARASOLID le noyau de modélisation au monde par Siemens a été intégrée dans Allplan 2016.
Nouveaux objets: cercle 3D et l'arc 3D.
Nouvel objet: spline 3D.
Vous pouvez modifier cercles 3D et les arcs 3D à l'aide des poignées et des boîtes de saisie de données.
Vous pouvez modifier splines 3D en utilisant les poignées.
Vous pouvez modifier cercles 3D et les arcs 3D à l'aide de la palette des propriétés.
Vous pouvez modifier splines 3D à l'aide de la palette des propriétés.
Sphères sont maintenant délimitées par les courbes.
Les cylindres sont maintenant délimitées par les courbes.
Vous pouvez modifier à l'aide de sphères poignées et les boîtes de saisie de données.
Vous pouvez modifier à l'aide de cylindres poignées et les boîtes de saisie de données.
Nouveaux objets: objet général de 3D, surface 3D générale.
Palette des propriétés pour les nouveaux objets: objet général de 3D, surface 3D générale
Outil 'Extrusion' avec un aperçu du plan de travail
Outil 'Extrusion' avec une nouvelle option pour créer de nouveaux éléments
L'utilisation de 'Extrusion', vous pouvez extruder une surface plane d'un élément courbe.
Nouveau «Modifier bord décalées 'outil de solides 3D polygonaux et de surfaces 3D
Nouvel outil "Rotate"
Nouvel outil 'Extrusion long du chemin "
Nouvel outil «Loft»
Nouvel outil «Chemin Sweep '
Nouvel outil "chanfrein Edge '
Nouvel outil "Filet Edge '
Nous avons amélioré l'outil «Parallel Lines» pour les lignes courbes 3D et 3D.
En utilisant les «combiner des lignes de Faire Polylines de l'outil, vous pouvez maintenant modifier les lignes 3D.
En utilisant les 'split polylignes en lignes discrètes de l'outil, vous pouvez maintenant modifier les lignes 3D.
Utilisation de l'outil «Intersect 2 entités, vous pouvez maintenant modifier les lignes 3D.
Utilisation de l'outil «chanfrein», vous pouvez maintenant modifier les lignes 3D.
Utilisation de l'outil «Filet», vous pouvez maintenant modifier les lignes 3D et courbes 3D.
Nous avons élargi le filtre d'élément pour inclure les nouveaux éléments: cercle 3D, 3D arc, spline 3D, objets 3D générale, surface 3D général.
Utilisation de la «convertir les éléments 'outil, vous pouvez convertir cercles 3D, des arcs et des splines 3D 3D en polygones.
Utilisation de la «convertir les éléments 'outil, vous pouvez Polygonisation objets 3D généraux et les surfaces 3D générales.
Vous pouvez convertir des cercles en 2D et des arcs 2D à la 3D.
Vous pouvez convertir splines 2D à la 3D.
Vous pouvez appliquer l'outil «tranche» de lignes, polygones 3D 3D, 3D cercles, arcs 3D et splines 3D.
Vous pouvez appliquer l'outil «tranche» en objets 3D généraux et les surfaces 3D générales.
Vous pouvez assigner des attributs aux cercles 3D et splines 3D.
Vous pouvez modifier des éléments 3D avec des courbes à l'aide de fonctions booléennes.
Éléments 3D avec des courbes sont visibles dans les vues et coupes associatives.
Éléments 3D avec des courbes sont visibles dans les sections d'architecture et des images de lignes cachées.
L'option «Changer Archit. Propriétés ', vous pouvez assigner des attributs architecturaux, tels que des éléments de surface, du commerce et du matériel, à des objets 3D généraux et les surfaces 3D générales.
Les macros peuvent contenir des objets 3D généraux et les surfaces 3D générales.
Groupes d'éléments peuvent contenir des objets 3D généraux et les surfaces 3D générales.
Vous pouvez exporter des objets 3D généraux et les surfaces 3D générales de CINEMA 4D.
Vous pouvez exporter des objets 3D en général et les surfaces 3D générale en PDF 3D.
Allplan exporte cercles 3D et les arcs 3D sous forme de courbes à Rhino.
Allplan exporte splines 3D sous forme de courbes à Rhino.
Allplan importe cercles 3D et les arcs 3D sous forme de courbes de Rhino.
Allplan importe splines 3D sous forme de courbes de Rhino.
Allplan exporte cercles 3D sous forme de courbes à CINEMA 4D.
Allplan exporte splines 3D sous forme de courbes à CINEMA 4D.
Allplan importe cercles 3D et les arcs 3D sous forme de courbes de CINEMA 4D.
Allplan importe cercles 3D et les arcs 3D sous forme de courbes à partir d'Autocad (Allplan c'est mieux) (Allplan ce est mieux) (Allplan ce est mieux) (Allplan ce est mieux).
Allplan importe splines 3D sous forme de courbes à partir d'Autocad (Allplan c'est mieux) (Allplan ce est mieux) (Allplan ce est mieux) (Allplan ce est mieux).
Architecture
Améliorations générales
La barre d'outils "Filtrez Assistant 'fournit la nouvelle« Filtrer par remplissage' de filtre d'élément pour remplissages avec gradients.
Les menus contextuels du «groupe Room» et des éléments «histoire» offrent le «groupe Modifier des chambres ou des histoires» et «groupe d'étiquettes de pièces ou des histoires de les outils de modification.
Nous avons révisé la boîte de dialogue pour 'Remplacer Symbole intelligente, SmartPart': vous pouvez maintenant trouver des descriptions claires pour les différentes options.
L'outil «Smart Window and Door Symboles" ne sera plus disponible dans les versions futures. Par conséquent, Allplan émet un message à cet effet lorsque vous ouvrez cet outil.
SmartParts
En utilisant l'option «Volets roulants», vous pouvez maintenant définir la position de volets roulants pour SmartParts de fenêtres et de portes SmartParts. Vous pouvez ainsi définir des rails et des boîtiers.
Vous pouvez choisir de nouveaux types de battants pour fenêtre SmartParts. Par exemple, vous pouvez créer des fenêtres à guillotine bas.
Vous pouvez choisir de nouvelles garnitures pour SmartParts de porte: «poignée de porte avec rosette» et «poignée de porte avec rosette.
matériel de panique est maintenant disponible pour SmartParts de porte.
On peut définir la distance entre la poignée de fenêtre et le cadre inférieur séparément de chaque côté. Ceci est important pour la construction sans barrières.
On peut définir la distance entre la poignée de porte et le cadre inférieur séparément de chaque côté.
Vous pouvez définir la distance entre la barre d'appui et le niveau bas de la feuille de porte séparément pour chaque côté. Ceci est important pour les voies d'évacuation de planification.
Vous pouvez sélectionner les zones de style, en plus de l'éclosion, les modèles et remplit pour l'affichage des fenêtres et des portes en sections. Vous pouvez faire des réglages différents pour 2D et 3D.
Vous pouvez sélectionner les zones de style, en plus de l'éclosion, les modèles et remplit pour afficher volets roulants dans les sections. Cela est possible uniquement pour la 3D.
Utilisation des paramètres pour SmartParts, vous pouvez définir comment afficher un SmartPart placé dans un plan incliné. Vous pouvez choisir entre la représentation 2D et représentation 3D. Lorsque vous choisissez ce dernier, la représentation 3D de la SmartPart devrait planifier vue (comme d'habitude dans Allplan).
Icônes améliorées pour les rebords de fenêtre et accessoires.
Icônes améliorées pour les poignées de porte.
Amélioration icône de l'outil «Shading SmartPart '.
Vous pouvez modéliser portes à l'aide de l'outil «Porte SmartPart 'levage.
Vous pouvez trouver le nouvel outil «Skylight SmartPart 'dans le' général: toits, plans de sections de module.
Lorsque vous enregistrez SmartParts à la bibliothèque, Allplan crée automatiquement un aperçu de l'objet en vue isométrique.
Le «Shading SmartPart '- l'outil« Blinds propose plusieurs types.
La «Porte SmartPart '-' levage porte 'outil offre plusieurs types.
L'outil «Skylight SmartPart 'offre plusieurs types.
L'outil «transfert SmartPart Version ', qui convertit SmartParts partir de versions antérieures, convertit SmartParts appartenant à un groupe d'éléments.
Vous pouvez utiliser la commande PIPE dans l'éditeur SmartPart.
Présentation
Allplan 2016 utilise le moteur de rendu CineRender R15.
Lors du rendu avec CineRender, vous pouvez utiliser le 'occlusion ambiante "méthode de rendu avec différents paramètres.
Utilisation de la «fusion» ou d'un outil 'Ajouter' dans CINEMA 4D, vous pouvez mettre à jour votre modèle Allplan.
Lors du rendu avec CineRender, Allplan traite correctement certains formats bitmap.
Allplan utilise en interne l'option 'intensité photométrique »pour rendre tous les types de lumière. Ce produit résultat réaliste, en particulier lorsque vous utilisez le type de lumière «Zone» pour l'éclairage intérieur.
Le 'RTRender' type de vue offre la nouvelle, facile à utiliser «modèle blanc 'Cadre pour les modèles de papier.
Lorsque vous sélectionnez le critère d'arrêt "de qualité" pour le "RTRender 'type de vue, Allplan montre la progression en pourcentage (à la place d'un indicateur de temps). L'indicateur de pourcentage est plus précis.
Lorsque vous interrompez le calcul 'RTRender', Allplan l'indiquera au bas de la fenêtre.
Problèmes avec l'affichage des objets transparents superposés dans l'animation ont été éliminés par OpenGL 4.2 en conjonction avec les cartes graphiques NVIDIA et le pilote actuel. (Vous pouvez maintenant superposer jusqu'à 32 couches.)
Mouvement en douceur: si Allplan ne peut pas atteindre l'ensemble de taux de rafraîchissement, si réduit la qualité du modèle d'affichage.
Vous pouvez maintenant glisser textures directement depuis le navigateur à la palette «Surfaces». De même, vous pouvez faire glisser bitmaps directement depuis le navigateur à la palette 'Environnement'.
Lorsque vous utilisez les opérations de glisser-déposer pour les textures, Allplan marque les boutons de cibles possibles dans la palette «Surfaces».
Lorsque vous créez et enregistrez une texture dans le dossier de bureau, Allplan copie automatiquement au projet en cours.
Vous pouvez copier et coller les lumières de projets individuels ou tous les feux de projet.
Lors du changement de lumières, vous pouvez également aligner les coins de lumières de la région.
Vous pouvez modifier les propriétés de plusieurs lumières en une seule étape.
Les mises à jour «chemin caméra 'de la palette automatiquement pour refléter les caméras que vous définissez à l'aide de l'outil' Set de parcours de la caméra».
Quand vous retenez le nom de fichier dans l'outil 'Record Movie', Allplan émet un message vous demandant si vous souhaitez écraser le film.
Nous avons amélioré la précision pour dessiner les points de départ et les points de grands arcs et splines finaux.
Nous accéléré la mise à jour des sections complexes associatifs dans certains cas (section du modèle entier, symboles intelligents 3D).
Types de vue la «Sketch» ​​et «cachés» affichent les nouveaux éléments 3D (ou polygonales avec des courbes).
Les réglages que vous faites pour les bords cachés dans la palette «Vue de type 'pour' Animation 'appliquent également aux nouveaux éléments 3D.
En utilisant les 'Options' - 'Rooms', vous pouvez spécifier si vous souhaitez afficher les éléments de finition dans tous les types d'affichage ou dans les types de vues ombrées seulement (cachés, animation).
Tous types ombragées de vue (cachée, animation, croquis) éléments d'affichage sélectionné dans la couleur de sélection.
Visualisation des éléments 3D complexes avec des arcs et des courbes ne sont pas bloqués par tessellation; Allplan augmente l'étape de qualité par étape.
Utilisation de l'outil «modèle de film (menu 'Fichier' - 'Importer'), vous pouvez importer et utiliser des modèles de films enregistrés comme * .FIL fichiers dans les versions antérieures.
Ingénierie
Section long d'une courbe
Vous pouvez afficher ou masquer les fichiers de dessin et éléments à l'aide d'un filtre.
Allplan conserve la position de la section lorsque vous masquez éléments.
Vous pouvez créer une représentation congelés ou associative de la section. Seule la section est reliée avec le modèle.
Vous pouvez également cet outil pour les nouveaux éléments 3D généraux, trop.
Nous avons ajouté des fonctionnalités au menu contextuel de la section «long d'une courbe.
Vous pouvez utiliser l'outil de la nouvelle «Section Dimension 'de dimensionner sections. Vous pouvez trouver ce nouvel outil dans le module 'Bridge et génie civil »et dans le menu contextuel.
Importer LandXML données
Utilisation de l'outil «Importer LandXML données (menu 'Fichier' - 'Importer'), vous pouvez importer des points de terrain 3D et lignes de localisation de l'itinéraire.
Allplan importe l'emplacement des lignes de route comme des éléments composites.
Un fichier de dessin sans nom devient le nom du fichier.
Attributs de renfort BIM
Utilisation du gestionnaire d'objet, vous pouvez assigner des attributs à des barres d'armature et des maillages placés, un tel matériau, la production comme élément préfabriqué ou sur site, la phase de construction et ainsi de suite.
Allplan prend ces attributs en compte lors de l'exportation et de l'importation de données de la SFI.
Vous ne pouvez pas assigner des attributs à un renforcement placés dans SmartParts.
Nous avons ajusté les outils généraux et spécifiques ingénierie modification.
Nous avons ajouté des fonctionnalités au menu contextuel d'éléments de renforcement.
Vous pouvez trouver le nouveau «Structural Analysis View 'option d'exportation dans les paramètres pour l'export IFC.
Allplan exporte les éléments suivants: poteau, poutre de downstand, dosseret poutre, dalle, panneau, de murs.
Vous pouvez créer un rapport des éléments exportés.
Vous pouvez exporter des ouvertures dans les murs, les dalles et panneaux
Daniel - MMC Construction
MessagePosté le: Jeu 30 Juil 2015 - 14:05    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
mise a jour dispo 2016_0_1
Les membres suivants remercient AdrienSahe pour ce message :
bco (30/07/15), Lemmy (31/07/15)
MessagePosté le: Jeu 30 Juil 2015 - 14:29    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Hotfix Allplan 2016-0-1
Release Notes
General
Basic
Setup and Licensing
We improved offline licensing.
You can now select the trial license during Allplan Setup.
In addition, you can see the number of the current license container in the license settings.
We improved License Server Setup based on WIBU CodeMeter.
We improved the process of creating the configuration file when you install the license server for the first time.
License settings no longer open when you create support requests (Hotinfo) or select 'Information' - 'Version'.
General
We corrected inconsistencies that might have occurred in conjunction with some graphics cards when you pointed to certain elements converted from earlier versions.
We enlarged the 'Project attributes' dialog box ('New Project, Open Project' - 'Properties' - 'Assign attributes').
We sped up the 'Undo' and 'Redo' tools when you copy, move and delete elements.
After you have switched off an architectural section, it is no longer displayed in the viewport toolbar.
While Allplan is running, the viewport toolbar retains its position when you connect additional screens with the computer (Windows 8.1).
The system angle does not change when you open and close 'Print Preview'.
Workgroup
Allplan starts without issuing a message even if the project you opened last contains active drawing files with layers set to 'hidden, frozen'.
Options
When you reset the options, Allplan includes the setting of the 'Line type for ISO curves of 3D elements' option (in 'Options' - 'Desktop environment' - 'Display').
Libraries
Allplan saves a library element only if its file name consists of valid characters. Otherwise, the program issues a message.
Draft
We improved the 'Reshape Surface Element, Architectural Area' tool.
Advanced Draft
We expanded the dialog box for 'Composite Element'.
Layouts
'Export PDF Data' exports bitmaps in the correct display sequence, regardless of the resolution set.
Interfaces
DXF, DWG, DGN Export
Allplan no longer exports wizards together with XRefs to DWG.
Allplan Exchange Layout Distribution: the 'Highlight reference points' option (in 'Options' - 'Dimension line') no longer affects the export of layouts with the 'Export.nth' exchange favorite to DWG format. You can now export layouts as you would using 'Export' ('File' menu).
DXF, DWG, DGN Import
You can now import special DWG files containing text styles without names into Allplan.
Polylines in DGN files retain their original RGB color values when you explode and import them into Allplan.
Dimension lines in DGN files will be imported in their entirety into Allplan.
You can import DWG files containing dimension lines with double reference points or dimensioned points even if the units are very small, such as millimeters, centimeters or inches.
Bonus Tools
3D Modeling
We improved the processing of general 3D curves imported from Rhino.
Allplan correctly stops filleting or chamfering elements that point into the same direction or that form a straight line.
We improved the 'Sweep Path' tool when applied to complex geometries with only a single path.
We adapted element selection in the new 3D tools ('Fillet Edge', 'Chamfer Edge', 'Modify Edge Offset') to the Allplan default: opening a selection rectangle no longer cancels the selection you have already made. Instead, you can select more points.
Using the 'Union' tool, you can now convert solids imported as 3D surfaces from other programs to 3D objects.
You can now use capital letters to enter default labels in 'Section Along Curve'.
Smart symbols with general 3D objects are visible in sections you create with 'Section Along Curve'.
Fixtures
We improved the process of copying fixture SmartParts.
SmartParts
Programming SmartParts: the GOSUB command can now process labels with umlauts.
Architecture
Walls, Openings, Components
You can place both door swing symbols for Smart French door symbols with two door leaves (for example, taken from the wizards for building alteration).
We improved the process of creating spline-shaped linear components along closed curves in conjunction with area detection using additional point and the number of segments set to a great value.
Using the 'Facade' tool, you can insert smart symbols you created with 'Smart Window and Door Symbols'.
Stair
If you modify the rise of a stair you created with the 'Stair Wizard' in a drawing file in edit mode, the drawing file assignment of the stair will not change.
Engineering
Shell
When you exit the 'Show Clipping Path' tool in associative sections, Allplan no longer issues the unnecessary message.
Even though you had correctly created the model and the associative sections in different drawing files, Allplan issued a message if the drawing file with the sections was open in edit mode. We removed this message.
After you have modified 3D elements, Allplan correctly updates the visibility of layers in associative views and sections.
Associative sections: Allplan displays the lines separating the new general 3D objects from the components in the same way as those separating the 3D solids from the components.
Bar reinforcement
We improved the rearrangement of reinforcement SmartParts.
After you have adjusted bars using 'Stretch Entities', Allplan correctly places the mark number; its position does not change.
Lengthening or shortening bars using 'Stretch Entities' no longer affects the remaining bars of the placement.
We improved the analysis of the bar length in circular reinforcement.
We removed the 'Engineering' - 'Bar reinforcement - element plan' legend.
Terrain
Site Plan
Allplan correctly updates attributes of composite elements when you open the 'Properties' palette.
Allplan no longer issues a message when you change the format properties (pen, line, layer, color) of composite elements in the 'Properties' palette.
Presentation
Animation
The Phong angle also has an effect on general 3D surfaces and objects you created from polylines using 'Loft', 'Sweep Path' or 'Extrude Along Path'.
When editing the camera path, you can add a new camera immediately after you have deleted a camera.
Traduction Google :
Citation:
Notes De Version
Général
De base
Nous avons amélioré licence déconnecté.
Vous pouvez maintenant sélectionner la licence d'essai pendant Allplan Setup.
En outre, vous pouvez voir le numéro du conteneur de licence actuelle dans les paramètres de la licence.
Nous avons amélioré la configuration du serveur de licence basée sur WIBU CodeMeter.
Nous avons amélioré le processus de création du fichier de configuration lorsque vous installez le serveur de licences pour la première fois.
paramètres de licence ne sont plus ouverte lorsque vous créez des demandes de soutien (Hotinfo) ou sélectionnez «Information» - «Version».
Général
Nous avons corrigé les incohérences qui ont pu avoir lieu en conjonction avec certaines cartes graphiques lorsque vous l'avez fait à certains éléments convertis à partir de versions antérieures.
Nous avons élargi la «attributs projet« boîte de dialogue («Nouveau projet, Open Project '-' Propriétés '-' assigner des attributs ').
Nous accéléré le 'Annuler' et 'Refaire outils »lorsque vous copiez, déplacer et supprimer des éléments.
Après avoir éteint une section d'architecture, il est plus affiché dans la barre d'outils de la fenêtre.
Alors que Allplan est en marche, la barre d'outils de la fenêtre conserve sa position lorsque vous vous connectez écrans supplémentaires avec l'ordinateur (Windows 8.1).
L'angle du système ne change pas lorsque vous ouvrez et fermez "Aperçu avant impression".
Groupe De Travail
Allplan démarre sans délivrer un message, même si le projet que vous avez ouvert contient dernière des fichiers de dessin avec des couches actives fixés 'hidden, gelé ».
Options
Lorsque vous rétablissez les options, Allplan comprend le réglage de la 'Type de ligne pour les courbes ISO d'éléments 3D de l'option (en' Options '-' environnement de bureau "-" Affichage ").
Bibliothèques
Allplan enregistre un élément de bibliothèque que si son nom de fichier est constitué de caractères valides. Dans le cas contraire, le programme émet un message.
Avant-projet
Nous avons amélioré l''élément de surface Reshape, espace architectural' outil.
Projet avancée
Nous avons élargi la boîte de dialogue pour 'Composite Element ».
Layouts
'Exporter des données PDF' exportations bitmaps dans la séquence d'affichage correct, indépendamment de l'ensemble de la résolution.
Interfaces
Allplan ne exporte plus sorciers avec XRefs à DWG.
Allplan échange Disposition Distribution: l'option «points de référence» Faits saillants (en 'Options' - 'ligne de cote') ne touche plus l'exportation de mises en page avec l'échange préférée 'Export.nth' au format DWG. Vous pouvez maintenant mises à l'exportation comme vous le feriez avec (menu «Fichier») «exportation».
DXF, DWG, DGN importation
Vous pouvez maintenant importer des fichiers DWG spéciaux contenant des styles de texte sans noms dans Allplan.
Polylignes dans les fichiers DGN conservent leurs valeurs d'origine de couleur RVB lorsque vous exploser et de les importer dans Allplan.
lignes de cote dans les fichiers DGN seront importées dans leur intégralité dans Allplan.
Vous pouvez importer des fichiers DWG contenant des lignes de cote avec le double de points de référence ou des points cotés, même si les unités sont très petites, comme millimètres, centimètres ou en pouces.
Outils extra
Modélisation 3D
Nous avons amélioré le traitement des courbes 3D générales importées à partir de Rhino.
Allplan arrête correctement éléments de filetage ou chanfreinage qui pointent dans la même direction ou telle forme une ligne droite.
Nous avons amélioré l'outil «Trajectoire» lorsqu'il est appliqué à des géométries complexes avec une seule voie.
Nous avons adapté la sélection d'éléments dans les nouveaux outils 3D («Filet Edge ',' chanfrein Edge ',' Modifier bord décalées ') à la valeur par défaut Allplan: l'ouverture d'un rectangle de sélection plus annule la sélection que vous avez déjà fait. Au lieu de cela, vous pouvez sélectionner d'autres points.
En utilisant l'outil «l'Union», vous pouvez maintenant convertir solides importés surfaces 3D à partir d'autres programmes à des objets 3D.
Vous pouvez maintenant utiliser des majuscules pour entrer étiquettes par défaut dans «Section long d'une courbe.
Symboles intelligents avec des objets 3D générales sont visibles dans les sections que vous créez avec «Section long d'une courbe.
Calendrier
Nous avons amélioré le processus de copie SmartParts de fixation.
SmartParts
Programmation SmartParts: la commande GOSUB peut maintenant traiter des étiquettes avec des trémas.
Architecture
Murs, ouvertures, Composants
Vous pouvez placer les deux symboles de swing de portes for Smart symboles de portes françaises avec deux battants de la porte (par exemple, pris des assistants pour la construction de la modification).
Nous avons amélioré le processus de création de composants linéaires en forme de spline le long des courbes fermées en conjonction avec détection de zone en utilisant le point supplémentaire et le nombre de segments fixés à une grande valeur.
Utilisation de l'outil «Façade», vous pouvez insérer des symboles intelligents que vous avez créés avec «Smart Window, de porte '.
Escalier
Si vous modifiez la montée d'un escalier que vous avez créé avec le "Stair Wizard 'dans un fichier de dessin en mode édition, l'affectation de fichier de dessin de l'escalier ne changera pas.
Ingénierie
Coquille
Lorsque vous quittez l'outil 'Show Clipping Path »dans les sections associatives, Allplan ne délivre plus le message inutile.
Même si vous aviez correctement créé le modèle et les sections associatives dans les différents fichiers de dessin, Allplan a publié un message si le fichier de dessin avec les sections a été ouverte en mode édition. Nous avons supprimé ce message.
Après avoir modifié des éléments 3D, Allplan met à jour correctement la visibilité des calques dans les vues et coupes associatives.
Associatifs sections: Allplan affiche les lignes de séparation des nouveaux objets 3D générales des composants de la même façon que celles séparant les solides 3D à partir des composants.
Bar renfort
Nous avons amélioré le réarrangement des SmartParts de renfort.
Après avoir réglé les barres en utilisant des «entités stretch ', Allplan met correctement le numéro de la marque; sa position ne change pas.
Allongement ou raccourcissement barres en utilisant des «entités de stretch 'non plus sur les barres restantes du placement.
Nous avons amélioré l'analyse de la longueur de la barre en renfort circulaire.
Nous avons enlevé le «génie» - «Bar renfort - plan d'élément« légende.
Terrain
Plan Du Site
Allplan met à jour correctement les attributs d'éléments composites lorsque vous ouvrez la palette "Propriétés".
Allplan plus émet un message lorsque vous modifiez les propriétés de format (plume, trait, couche, couleur) d'éléments composites dans la palette "Propriétés".
Présentation
Animation
L'angle Phong a également un effet sur les surfaces générales 3D et objets que vous créé à partir de polylignes à l'aide de «Loft», «Trajectoire» ou «Extruder le long chemin '.
Lors de l'édition de la trajectoire de la caméra, vous pouvez ajouter un nouvel appareil photo immédiatement après que vous avez supprimé une caméra.
Les membres suivants remercient Mazariaty pour ce message :
Lemmy (31/07/15), paupiette22 (03/08/15)
paupiette22
MessagePosté le: Lun 3 Aoû 2015 - 15:33    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Je suis vraiment déçu, ils auraient quand même pu régler les problèmes d’arases de toit en mansarde, je trouve que c'est assez grave mais bon.... certainement pour la prochaine mise à jour...
MessagePosté le: Sam 29 Aoû 2015 - 22:07    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Hotfix Allplan 2016-0-2
Pas encore (à cette heure en tous cas) sur connect , c'est mon "allplan" qui se mets à jour tout seul ...
j'espère (je sers les fesses ) que cela ne va pas entrainer d'autres soucis. Normalement ce devrait même être l'inverse...à voir donc... Wink
BOXPLAN
MessagePosté le: Mer 16 Sep 2015 - 11:15    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Salut à toutes et tous,
Depuis la mise à jour 2016-0-2, j'ai quelques bugs sans gravité : dans certaines boites de dialogue, le bouton "OK" est vierge, il apparait mais sans le "OK" !!!!
C'est le cas pour la boite [Entrer un texte].
Je suis sous Windows 10 depuis la version 2016-0-1.
JC
Jérôme
MessagePosté le: Mer 16 Sep 2015 - 11:24    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Oui j'ai la même chose que toi, un peu bizarre car dans la boîte de dialogue du mur par exemple, le "Ok " y est toujours.
MessagePosté le: Mer 16 Sep 2015 - 11:35    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Oui, cela fait partie de la liste des "erreurs" rencontrées avec Windows 10...
Les dialogues des fonctions ne sont pas développés avec les mêmes composants que les dialogues d'ouverture ou d'enregistrement de fichiers, d'où les variations de comportement.
Si on agrandit une fenêtre de dialogue d'ouverture ou d'enregistrement de fichiers, il est impossible de la réduire même après avoir redémarré le logiciel. Surtout NE JAMAIS afficher cette fenêtre en plein écran avec l'icone "Agrandir" ou en double-cliquant sur le haut de la fenêtre car elle ne pourra plus être réduite !
Cela peut paraître bizarre, mais c'est surtout gênant que Windows 10 ne prenne pas en compte ces éléments comme le faisait les Windows précédents, car cela n'arrive pas seulement à Allplan... Sad
Jérôme
MessagePosté le: Mer 16 Sep 2015 - 11:48    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Pour ma part, j'ai le bug du "Ok" sur windows 7
MessagePosté le: Mer 16 Sep 2015 - 11:49    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
alors pour le OK visible ou pas c'est aussi avec W7PRO ... mais bon ce n'est vraiment pas grave ... Wink
édit : grillé par Jérôme
MessagePosté le: Mer 16 Sep 2015 - 12:15    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Ah... Je ne l'ai pas avec Windows 8.1.
Ils ont une fenêtre d'ouverture/enregistrement qui n'est pas exactement celle par défaut du Framework standard.
Ceci doit expliquer cela car par exemple avec Alltransfer (.Net 2.0) ou wizYsmart Manager (.Net 4.5), je n'ai pas ce soucis...
MessagePosté le: Jeu 17 Sep 2015 - 15:43    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
aujourd'hui je suis passé sous la version Hotfix Allplan 2016-0-3
avis à la population ..
pas encore trouvé les textes d'explications des améliorations mais ils devraient bientôt être dispos sur le connect ..
Jérôme
MessagePosté le: Jeu 17 Sep 2015 - 15:46    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Nemetschek m'a dit hier de ne pas faire tout de suite les mises à jours car il allait y en avoir une série de plusieurs.
Après si elles sont rapides je ne vois pas trop où est le problème mais bon...
MessagePosté le: Jeu 17 Sep 2015 - 20:26    Sujet du message: Mises à jour Allplan 2016 Répondre en citant
Release Notes
General
Allplan and Windows 10
You can now use Allplan in conjunction with notebooks running Windows 10.
Quality Reporter correctly recognizes and displays Windows 10.
Hotinfo correctly recognizes and displays Windows 10.
Setup, Licensing, Auto-Update
We stabilized and improved WIBU licensing for Allplan in various places.
If the license server cannot display licenses due to missing administrator privileges, you get a corresponding message.
When you install Allplan as a viewer, Setup automatically chooses the country that is set for 'Region and Language' on the Windows Control Panel.
It is no longer possible to stop Allplan Auto-Update, making sure all software components always update correctly.
We improved Auto-Update, making sure the update runs through even if the Internet connection gets lost.
When importing project backups from Allplan 2014 and 2013, you now have the option to convert the data and to import them into a new project.
After having upgraded, you can no longer select the 'Hardlock' (dongle) option.
Building structure
You can rename drawing files in the building structure quickly and easily.
Basic
Interfaces
DWG interface
DWG export takes into account arcs between clothoids in composite elements.
DGN interface
Point symbols get the correct size when you export complex layouts to DGN.
BIM+ interface
Allplan transfers default attributes and user-defined attributes to BIM+.
Allplan transfers its internal element numbers to BIM+.
Allplan does not update objects that have not changed when you export data to BIM+.
iTWO interface
Finish specifications identified as areas to be subtracted (with the factor -1) are correctly exported to iTWO.
Layout
The 'Print Layouts' tool does not take into account margins when you choose PDF export and define a resizing factor.
Architecture
When defining the 'Sill Height', you can enter any value for deltaBL (for example, for the floor structure).
Engineering
Bar Reinforcement
Using 'Convert, Match Elements', you can place design entities converted to reinforcing bars one after the other.
When modifying a linear bar placement, you can redefine the placing line in the 'Placing region' area of the 'Properties' palette.
Steel information and bending information you created for area reinforcement placed in polygon (with 'Bending Machine' in the BVBS standard) get the correct number of pieces.
Using 'Modify Placement', you can change the number of pieces quickly and easily a number of times.
FRILO Plate
We stabilized export of complex plates with large radii to Frilo. The FE program of FRILO Software GmbH cannot process circular beams. Therefore, you cannot export these components.
Terrain
Site Plan
We increased the maximum values you can enter for the reference height in 'Modify Terrain Point Height'.
Presentation
Animation
You can quickly and easily save custom surfaces as favorite files straight from the 'Surfaces' palette.
Allplan International
As soon as Auto-Update is complete, you get a message. This message is in the selected language.
MessagePosté le: Aujourd’hui à 15:13    Sujet du message: Mises à jour Allplan 2016
Aller à la page: 1, 2, 3, 4, 5, 6, 7, 8  >
Page 1 sur 8
