Mises à jour Allplan 2015
Aller à la page: <  1, 2, 37, 8, 911, 12, 13  >
MessagePosté le: Mer 10 Déc 2014 - 17:50    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
Mr. Green
MessagePosté le: Mer 10 Déc 2014 - 17:50    Sujet du message: Publicité
MessagePosté le: Lun 15 Déc 2014 - 17:19    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
saperlipopette,
je viens de tester volontairement un rendu un peu chargé en arbres arbustes textures personnage 3D voiture et d'autres encore..................>bluffant
un temps de 4 mn 35 pour un rendu très acceptable sans retouche totoshop.
je voulais simplement dire que si on peut critiquer certains points d'Allplan, celui ci en tout cas mérite des lauriers.
MessagePosté le: Ven 16 Jan 2015 - 11:49    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
Allplan 2015-1-2 :
Citation:
General
We improved the display of hidden line images in projects with rotated plan view.
Improved 3D modeling with handles.
When it comes to selecting documents for the 'Old-New-Comparison', you can now choose the fileset structure, too.
You can now use RealTime rendering for models with advanced XRefs in the background.
Basics
You can use specific 32-bit add-on programs with 64-bit Allplan.
Building Structure
Clearing and selecting the 'Derived objects' check box does not affect the hierarchic levels on the right side of the building structure.
Workgroup Manager - 'Open on a Project-Specific Basis' - 'Building structure' tab: if another user is currently editing a drawing file you want to open in reference mode, all you need to do is click this drawing file. You no longer have to open the shortcut menu.
Dimension Lines
We improved the 'Stretch Entities' tool for 2D elements with elevation points.
We improved the preview of dimension line properties in conjunction with a black background.
Layout
Improved printing with Nemetschek raster drivers.
When printing several layouts, you can apply the resizing factor to all layouts selected.
When calculating the size of title blocks, Allplan no longer takes into account label styles with overlapping texts; the title block stays where it is.
Interfaces
DWG
When importing DWG files with element groups, Allplan assigns a component ID not only to the element group but also to its elements. You can even export the data to IFC.
We improved the layer assignment for exporting layouts to DWG with exchange favorite 2.
When importing DWG files with bitmaps, Allplan detects and imports more bitmap formats.
You can import layouts in DWG format even if the layout name includes spaces.
bim+
You can now export openings in user-defined architectural elements to bim+.
Windows and doors get the correct element type during export to bim+.
When updating to bim+, Allplan handles deleted drawing files correctly.
Bonus Tools
Bridge and Civil Engineering
'Section Along Curve': it is easier to match a new element for the clipping path.
'Bridge, Civil Engineering Component': the icons for selecting the view are positioned correctly.
Architecture
Rooms, Surfaces, Stories
We sped up calculations of finish specifications in viewports. You will see the 'Fill graphics memory' message only if you work with large volumes of data.
Space Allocation Wizard starts without issuing a message.
Frame Construction: Rafters, Roof Beams, Posts
You can apply the 'Rotate' and 'Stretch Entities' tools to elements created as 'Steel, Timber Elements'.
Presentation
Animation
You can load a favorite while editing a camera path.
You can modify lamps correctly.
Engineering
Bar Reinforcement
If you select the 'Bar length, mesh length - calculate actual length' and 'Segment lengths - outer dimensions' options in the 'Options' - 'Reinforcement' - 'Label' - 'Schema' area, you can see the actual length in the bar shape palette.
A mark number enclosed in a circle is placed correctly in relation to a dimension line of the comb type.
Allplan creates additional placing regions of area reinforcement with different mark numbers correctly.
Allplan no longer displays a message when you modify the layers of text leaders and texts.
You can copy reinforcement more quickly.
Improved full schemas.
You can always see a preview of the placement label.
Allplan always combines identical bars to a single mark number.
Using 'Shape for each side of polygon', you can modify area reinforcement placed along recesses more easily.
Steel Schedules
You can analyze layers in reports and legends even if some layers are set to hidden.
Modifying general texts no longer affects steel legends.
Detailing
The 'Optimize working with large coordinates' option does not affect detailing windows.
Terrain
Digital Terrain Model
Allplan takes the text height from the Text module when labeling contour lines in a digital terrain model.
Allplan International
Improved localized attributes.
Netherlands
Text in the building structure appears in the correct order.
AdrienSahe (16/01/15), Dominici Gilles (16/01/15), Lemmy (20/01/15)
MessagePosté le: Ven 16 Jan 2015 - 12:20    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
tant que ce you pour la remontée d'info ! Okay
MessagePosté le: Ven 16 Jan 2015 - 12:31    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
Comprends pas ce que tu dis PhilC.... Il faut attendre ou c'est bon pour l'installer.
MessagePosté le: Ven 16 Jan 2015 - 12:33    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
il disait, il me semble : thank you
MessagePosté le: Ven 16 Jan 2015 - 12:36    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
Oui, c'est bon.
Patch disponible directement dans Allplan, menu "?", puis "Mise à jour".
Egalement téléchargeable sur Allplan Connect, rubrique "Téléchargements", puis "Correctifs récents".
gael
MessagePosté le: Ven 16 Jan 2015 - 12:58    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
Ce qui est sympa depuis la 2015-1-1, c'est la possibilité de diminuer la puissance du processeur en RTRENDER :
Cela t'évite d'avoir l'impression d'être sur le tarmac de l'aéroport Wink
J'essais de suite la 1-2.
Sur des versions précédentes, peut-être 2011 ou 2012 j'avais une recherche automatique de mise à jour allplan dans la barre de tache Windows...c'est supprimé?
C'est au pied du mur, qu'on voit... mieux le mur.
MessagePosté le: Ven 16 Jan 2015 - 13:16    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
bien vu Adrien Wink Very Happy
@Gwada moi non plus certaines fois je ne comprends pas ce que tu écris ... Mr. Green Very Happy
MessagePosté le: Ven 16 Jan 2015 - 13:39    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
Pourtant je reste dans la simplicité... Bon je viens de télécharger la Maj sur connect.
Je vais tester un rendu.
MessagePosté le: Ven 16 Jan 2015 - 15:09    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
Si je comprends bien, c'était avant l'ajout dans Allplan de "Allplan Update"...
Je pense que tu parles de "Nemetschek Update" que j'avais créé et développé à partir de 2007 pour aider les utilisateurs français à avoir un Allplan avec ses compléments toujours à jour. Cet outil est abandonné maintenant. Wink
MessagePosté le: Ven 16 Jan 2015 - 15:18    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
BCO, tu peux me développer un outil qui fait les plans tout seul ?
merci.
MessagePosté le: Ven 16 Jan 2015 - 15:32    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
Oui, pourquoi pas, mais cela risque de ne pas correspondre aux besoins de tes clients !!! Mr. Green
MessagePosté le: Ven 16 Jan 2015 - 16:19    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
rien de bien nouveau sous le soleil ?
MessagePosté le: Ven 16 Jan 2015 - 16:53    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
Shocked
gael
MessagePosté le: Ven 16 Jan 2015 - 16:58    Sujet du message: Mises à jour Allplan 2015 Répondre en citant
BCO, tu as raison, il s'agit bien de Nemetschek Update, Nemetschek intègre au fur et à mesure des versions...
à quand wizysmart dans allplan...
J'ai un message d'erreur au sujet de la mise à jour :
"En\NemAll_Wpf_Basic_PlotLayout.resources.dll
NP_DataExchange.dll"
C'est grave docteur?
MessagePosté le: Aujourd’hui à 18:27    Sujet du message: Mises à jour Allplan 2015
Page 8 sur 13
