Mises à jours allplan 2014
Aller à la page: <  1, 2, 311, 12, 13
MessagePosté le: Ven 29 Aoû 2014 - 10:02    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Hotfix Allplan 2014-1-5
Logiciel : Allplan
Version : 2014
General
Quality Reporter functionaliy was extended.
Basics
Workgroup Manager
Activating tools when modifying layouts under Workgroupmanager and Workgroup Online was accelerated.
Improved locking of layouts.
Interfaces
After data export to Autocad (Allplan c'est mieux) 2007 using prototype files the layers in the viewports are not frozen anymore.
When you export layouts to Autocad (Allplan c'est mieux), the display sequence of the layout elements is maintained in the viewports.
Draft
Improved workflow when choosing a tool from the shortcut menu in the workspace with elements already selected: the selected element can be modified immediately.
General improvements in activating and quitting the Line tool.
Plan Layout
General improvements in selecting and closing the Plan Layout module.
Architecture
After having converted data from Allplan 2012 to 2014 attribute groups and userdefined attributes are displayed again.
Basics: Walls, Openings, Components
When modifying a smart symbol's geometry you can use the area detection tool again.
General improvements in the Wall dialog box.
Rooms, Surfaces, Stories
Label Styles with userdefined attributes can use the unit m² again.
Engineering
Bar reinforcement
General improvements when modifying reinforcement.
Terrain
DTM
When you label contour line of a Digital Terrain Model you can apply background fill to the text again.
Cadastral Plan for Conduits
After converting the data from V2013 to 2014 the conduit objects are displayed correctly in plan view again.
MessagePosté le: Ven 29 Aoû 2014 - 10:02    Sujet du message: Publicité
MessagePosté le: Ven 29 Aoû 2014 - 10:07    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Hotfix Allplan 2014-1-6
Version : 2014
General
Quality Reporter was improved.
You can import large layer structures (*.dat) again.
Data Conversion
One of the messages you can see when you convert layouts works correctly again.
XRef
Layouts with XRefs embedded in drawing files open more quickly.
New Project, Open Project
When you switch the layer structures from Office to Project while creating or modifying a project, Allplan behaves as in the previous version 2013: it also copies the external layers to the project.
Allplan no longer issues a message when you switch projects while the Library palette is open, showing your own symbols.
Exchange
Allplan Exchange exports layouts with openings in associative views correctly to PDF format.
Online help
Better full-text search in the help: you can now look for several terms. Open the online help to benefit from this improved feature.
Basic
Draft
Better island detection when you work with area detection.
Engineering
Bar Reinforcement
The "Apply background fill" setting in the Text module no longer affects dimension text in associative legends.
Associative Views
Elevation points in associative sections are dimensioned correctly again.
MessagePosté le: Ven 31 Oct 2014 - 19:41    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Allplan 2014-1-7 :
General
Data Conversion
You no longer have any problems working with smart symbol definitions from version 2013.
Basic
Draft
We improved outline detection, thus speeding up area detection.
Architecture
Rooms, Surfaces, StoriesThe “Room” tool opens more quickly.
Engineering
Bar Reinforcement
Reinforcing bar placements in isometric views are consistent with the reinforcement model again.
Mesh Reinforcement
The "Apply background fill" setting in the Text module no longer affects dimension text in the "Mesh schedule - bending shapes" legend.
Allplan International
Layout
You no longer have any problems working with special characters in the layout structure.
_____________________________________________________
Allplan 2014-1-8 :
General
Allfa Sync
Replication works with 64-bit Allplan.
Mises à jour par Allplan Update (menu "?" > Mise à jour Allplan) ou par téléchargement sur Allplan Connect... Wink
Lemmy (04/11/14)
MessagePosté le: Jeu 18 Déc 2014 - 15:21    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Hotfix Allplan 2014-1-9
Architecture
If you have defined several layers of finishing specifications with conditions for a room, you can now analyze each layer correctly.
Reports
In reports, graphics of details are displayed correctly.
You can assign a pen and color for all graphics in reports on the 'Reports and quantity calculations' page in the 'Options'. This setting no longer affects the format properties of components in some reports.
Better localized reports.
Mises à jour par Allplan Update (menu "?" > Mise à jour Allplan)... Wink
Lemmy (18/12/14)
MessagePosté le: Jeu 18 Déc 2014 - 19:19    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Par le menu mise à jour chez moi ça ne fonctionne pas, d'habitude je passais par Allplan connect en mettant le patch en tant qu'administrateur, mais là il n'y est pas, comment faire dans ce cas ?
MessagePosté le: Jeu 18 Déc 2014 - 19:46    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Tu cliques sur "Rechercher maintenant" et tu télécharges alors le patch.
Tu quittes Allplan.
Ensuite, tu vas dans le dossier "C:\Données\Nemetschek\Allplan\Download\x64" (si tu es en 64 bits) et tu décompactes le fichier "Allplan Update 2014-1-9.zip".
Tu lances alors "Allplan Update 2014-1-9.exe" par un clic droit, puis "Exécuter en tant qu'administrateur".
Et là, ça fonctionne... Wink
MessagePosté le: Jeu 18 Déc 2014 - 20:06    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Bah voilà, y'avait qu'à demander... Smile
Super, ça roule.
Merci BCO
MessagePosté le: Sam 3 Oct 2015 - 18:58    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Pour info (un peu tardive...) :
Hotfix Allplan 2014-1-10
09/03/2015
Basic
Draft
"Fillet" with trimming: Allplan uses the fillet you selected.
Allfa Sync
When you export data using the NOI interface, coverings you defined with conditions for the room finish are always transferred. The program calculates the values for these coverings based on the areas that fulfil a condition.
You can click the "Show in Allfa" button only if Allfa Web is running.
Silent replication clearly detects elements that have changed but that have not been replicated yet.
Silent replication no longer issues messages blocking snychronization.
'Change Parent Object' now displays the room number in the message. Using the dialog box, you can change this number and assign it again.
Rumania
Improved toolbar for entering polylines.
___________________________________________________________
Hotfix Allplan 2014-1-11
13/07/2015
General
Print Layouts
The raster driver correctly processes any changes you make to the number of copies.
Interfaces
IFC Interface
Allplan imports the 'LongName' of 'Spaces' for use with the 'Room function'.
Facility Management
Allfa Sync
The message that appears when you create equipment by assigning smart symbols to items includes the number of equipment objects Alfa Sync will actually create.
When you combine rooms, Allfa Sync correctly updates the manual assignment of smart equipment symbols.
When you split rooms, Allfa Sync checks only the code to see whether it is unique.
MessagePosté le: Lun 5 Oct 2015 - 08:34    Sujet du message: Mises à jours allplan 2014 Répondre en citant
La version 2014 a toujours le droit d'avoir des mises à jour ?
Ca c'est bien alors Okay
MessagePosté le: Aujourd’hui à 16:15    Sujet du message: Mises à jours allplan 2014
Page 13 sur 13
