Mises à jours allplan 2014
Aller à la page: <  1, 2, 3 … , 11, 12, 13  >
MessagePosté le: Lun 19 Mai 2014 - 15:44    Sujet du message: Mises à jours allplan 2014 Répondre en citant
T'es en retard de presque une Guerre Dead, la 2015 va bientôt être annoncé Very Happy
(enfin dans moins de 6 mois Wink )
MessagePosté le: Lun 19 Mai 2014 - 15:44    Sujet du message: Publicité
MessagePosté le: Mar 10 Juin 2014 - 00:20    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Mise a jour 2014-1-3 disponible
on retiendra surtout le correctif des pilotes Nvidia ..
Note de publications :
Citation:
Hotfix Allplan 2014-1-3
Release Notes
General
Quality Reporter now includes additional details about current operating systems.
Hotinfo now includes additional details about current operating systems.
You can now update to the Nvidia GeForce 337.88 driver without any problems.
Basics
The program saves drawing file data more consistently.
Workgroup
Workgroup Online: you can now use projects without a dedicated online server.
Interfaces
DGN interface: you can import DGN V8 data without any problems.
CAD-TAI interface: better connection to Nevaris 2.0.
bim+ interface: better security in conjunction with Allplan.
Draft
"Area detection" ignores internal connection lines of areas you entered using the "Multi" option.
The system angle set does not change when you open animation windows.
Better "Last Point" option on the shortcut menu for entering points.
Since version 2014-0 you have been able to create fills as construction lines. In order to ensure that this does not happen accidentally, set the "Fills in construction line format" option to "Fills in construction line color" ("Options" - "Display" page). This is now the default setting.
Layout
We solved the issue leading to the "Error while reading the user-defined layout attributes...." message.
The new position of dimension text you moved does not change in the layout, regardless of the "Correct text direction" option and rotated layout elements.
Architecture
Walls, Openings, Components
You can enter the properties of walls and rooms more quickly.
You can move custom smart symbols from earlier versions in the z direction after you have chosen "Select Elements Intersected by Selection Window Only".
Engineering
SmartParts
You can select your own engineering SmartParts more quickly.
Lemmy (10/06/14), Mazariaty (12/06/14)
MessagePosté le: Mar 10 Juin 2014 - 11:28    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Pas mal de petites choses corrigées ou améliorées dans cette mise à jour, bonne cuvée Okay
MessagePosté le: Jeu 12 Juin 2014 - 16:07    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Tout se remet en place. J'avais besoin du pilote NVIDIA 337.88 pour faire fonctionner Allplan et Otane render 2.0.
Beaucoup de trifouille informatique en pagaille pour sortir juste des plans et perspectives...
MessagePosté le: Jeu 12 Juin 2014 - 16:32    Sujet du message: Mises à jours allplan 2014 Répondre en citant
ah ça ..Je me faisais la réflexion pas plus tard que tout à l'heure , depuis que je fais du dessin sur info j'ai l'impression que j'ai passé beaucoup plus de temps à faire de l'info que du dessin , à tel point que certain de mes clients ne m'appellent que pour des problèmes d'info !!! Shocked
au fait j'aimerais bien échanger avec toi sur octane Maza
MessagePosté le: Ven 11 Juil 2014 - 11:47    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Hotfix Allplan 2014-1-4
Release Notes
General
Basics
'Area detection' no longer finds elements in construction line format you hid using 'Show/Hide'.
The 'Divide Element' tool snaps to points again.
Layout
You can place filesets with detailing windows correctly in layouts if you work with projects you converted from an earlier version.
Using CTRL+A, you can select all layouts without any problems.
Interfaces
We improved DWG import.
Architecture
You can see the crosshairs when you modify the geometry in a smart symbol foil.
We improved label styles: pen and line type do not change when you replace label styles.
You can no longer use the 'Attributes' button to overwrite the Allright_Component_ID attribute in the properties of surface objects. In order to create reports, you can now find this attribute in the 'Special Architecture' category.
Engineering
You can use 'Move' to change shell entities within a view again.
We improved the 'Reinforcement schedule - bending shapes' report.
You can see the crosshairs when you modify bending shapes in the 'Reinforcement schedule - bending shapes' report.
MessagePosté le: Ven 11 Juil 2014 - 12:08    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Hotfix Allplan 04/01/2014
notes de mise à jour
général
Nous avons édité et corrigé divers messages de qualité Reporter, résultant en une version plus stable d’Allplan.
Notions de base
«Détection de zone » ne trouve plus d'éléments au format de la ligne de construction, que vous avez masqué en utilisant "Afficher / Masquer".
L'outil «Diviser élément« s'accroche aux points.
disposition
Vous pouvez placer les ensembles de fichiers avec des fenêtres détaillées correctement mises en page si vous travaillez avec les projets que vous avez converti à partir d'une version antérieure.
L'utilisation de CTRL + A, vous pouvez sélectionner toutes les configurations sans aucun problème.
interfaces
Nous avons amélioré DWG importation.
architecture
Vous pouvez voir le réticule lorsque vous modifiez la géométrie dans une feuille de symbole intelligent.
Nous avons amélioré styles d'étiquettes: stylo et le type de ligne ne changent pas lorsque vous remplacez styles d'étiquettes.
Vous ne pouvez plus utiliser le bouton 'Attributs de remplacer l'attribut Allright_Component_ID dans les propriétés des objets de surface. Afin de créer des rapports, vous pouvez maintenant trouver cet attribut dans la catégorie «Spéciale d'Architecture.
ingénierie
Vous pouvez utiliser 'Move' pour changer entités fictives dans une vue à nouveau.
Nous avons amélioré le «programme Renfort - flexion des formes de rapport.
Vous pouvez voir le réticule lorsque vous modifiez des formes de flexion dans le «programme de renforcement - flexion des formes de rapport.
Daniel - MMC Construction
MessagePosté le: Ven 11 Juil 2014 - 12:13    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Ah oui, merci pour la traduction... Embarassed
MessagePosté le: Ven 11 Juil 2014 - 12:14    Sujet du message: Mises à jours allplan 2014 Répondre en citant
- le probleme du curseur est réglé (en tout cas chez moi)
- la perte des propriété de format des layers. pas réglé
MessagePosté le: Ven 11 Juil 2014 - 12:19    Sujet du message: Mises à jours allplan 2014 Répondre en citant
merci pour l'info de màj
je vais installer
MessagePosté le: Ven 11 Juil 2014 - 15:28    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Le problèmes des pertes des aspect de surface n'est pas réglé avec ce patch.
je viens de l'avoir de nouveau
MessagePosté le: Lun 21 Juil 2014 - 13:52    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Pour installer le dernier correctif doit-on au préalable installer les correctifs d'avant ?
Merci d'avance
MessagePosté le: Lun 21 Juil 2014 - 14:05    Sujet du message: Mises à jours allplan 2014 Répondre en citant
S'il le faut, le fichier d'installation te le dira. Donc, essaie et voit si c'est demandé...
MessagePosté le: Lun 21 Juil 2014 - 15:05    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Parfait, et pas eu besoin d'installer les correctifs précédents.
MessagePosté le: Jeu 31 Juil 2014 - 20:46    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Allplan 2015 disponible,
suppression de la mise en post'it de ce sujet .
MessagePosté le: Ven 29 Aoû 2014 - 10:02    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Hotfix Allplan 2014-1-5
Logiciel : Allplan
Version : 2014
General
Quality Reporter functionaliy was extended.
Basics
Workgroup Manager
Activating tools when modifying layouts under Workgroupmanager and Workgroup Online was accelerated.
Improved locking of layouts.
Interfaces
After data export to Autocad (Allplan c'est mieux) 2007 using prototype files the layers in the viewports are not frozen anymore.
When you export layouts to Autocad (Allplan c'est mieux), the display sequence of the layout elements is maintained in the viewports.
Draft
Improved workflow when choosing a tool from the shortcut menu in the workspace with elements already selected: the selected element can be modified immediately.
General improvements in activating and quitting the Line tool.
Plan Layout
General improvements in selecting and closing the Plan Layout module.
Architecture
After having converted data from Allplan 2012 to 2014 attribute groups and userdefined attributes are displayed again.
Basics: Walls, Openings, Components
When modifying a smart symbol's geometry you can use the area detection tool again.
General improvements in the Wall dialog box.
Rooms, Surfaces, Stories
Label Styles with userdefined attributes can use the unit m² again.
Engineering
Bar reinforcement
General improvements when modifying reinforcement.
Terrain
DTM
When you label contour line of a Digital Terrain Model you can apply background fill to the text again.
Cadastral Plan for Conduits
After converting the data from V2013 to 2014 the conduit objects are displayed correctly in plan view again.
MessagePosté le: Aujourd’hui à 09:55    Sujet du message: Mises à jours allplan 2014
Page 12 sur 13
