Mises à jours allplan 2014
Aller à la page: 1, 2, 311, 12, 13  >
MessagePosté le: Jeu 28 Nov 2013 - 12:52    Sujet du message: Mises à jours allplan 2014 Répondre en citant
hello les filles
première mise à jour (hotfix) 2014-0-1 à l'instant chez moi ..
je vais tester pour voir les améliorations (s'il y en a Wink )
edit : je suis allé voir déjà sur allplanconnect les changements et améliorations ! reste à tester
General
Editing and correcting various messages issued by Quality Reporter led to a more stable Allplan.
Data Conversion
Data conversion of drawing files containing associative views was improved.
Elements in detailing windows on layouts are displayed correctly again.
When you upgrade the program to Allplan 2014, the data conversion of wizards in the office standard was improved.
Workgroup Online
No message will be issued when you import DWG data on standalone installations.
Basics
Layers
Format properties' setting "From layer, line style" now has the same effect on both 2D and 3D elements.
Text
In the "Text" dialog box, you can scroll long texts again by turning the mouse wheel.
Layout
In Layout mode, you may place symbols on layouts without restrictions.
Interfaces
iTWO
iTWO export: "Story" and "Topology" attributes were added to iTWO filter.
bim+
Layer names were aligned in Allplan and bim+.
bim+ data export: DTM elements can be exported to bim+ now.
Bonus Tools
3D Modeling
With the "Slice" tool, you can define the slicing plane by entering points on edges again.
Architecture
With the "Building Lists" tool, you can analyze drawing files in edit and reference mode again.
Rooms, Surfaces, Stories
Finish surfaces are shown correctly in animation now when you define the room finish using the Elements' method.
When you consecutively enter several rooms with finish surfaces, baseboards are not created automatically anymore.
Engineering
Associative Views
Creating Associative Views and Sections of large data was improved.
When you cancel the "View and Section Properties" dialog toolbar while the "Dimension Line" dialog box is open, now the dimension line properties are saved correctly.
When you save elements with Associative Views on hidden layers, those are computed correctly again.
Bar Reinforcement
Reinforcement data can be exported again using the "Create Excel Spreadsheet" tool.
Matching of curves was refined when you create bars using the "Match Edges" option.
You now can modify the bending pin factor of bars created with "Convert, Match Elements".
Doubled congruent bars can be activated correctly again.
Allplan International
Engineering reports using subreports were improved.
Program start of Turkish, Bulgarian and Romanian Allplan versions has been improved.
Note: In order to put this improvement into effect, you have to install the full installation package as an update, upgrade or new installation. With the present hotfix or Allplan's automatic update functionality, this improvement will not be achieved. You can download the full installation package from Allplan Connect - SERVICE - DOWNLOADS.
Switzerland
"Show Comments" option in "Reinforcement schedule - Switzerland.rdlc" was improved.
France
IFC log file was improved.
MessagePosté le: Jeu 28 Nov 2013 - 12:52    Sujet du message: Publicité
TRODAT
MessagePosté le: Jeu 28 Nov 2013 - 12:56    Sujet du message: Re: Mises à jours allplan 2014 Répondre en citant
hello les filles
Idem chez moi.
Eric
MessagePosté le: Jeu 28 Nov 2013 - 14:04    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Merci Phil, je passe en Post-it Okay et dans la bonne section....
MessagePosté le: Jeu 28 Nov 2013 - 15:22    Sujet du message: Mises à jours allplan 2014 Répondre en citant
oui je me suis encore gouré de section à vouloir faire tout vite !! Embarassed
MessagePosté le: Jeu 28 Nov 2013 - 15:32    Sujet du message: Mises à jours allplan 2014 Répondre en citant
No problemo, tu me dois une binouze Mr. Green
MessagePosté le: Jeu 28 Nov 2013 - 15:52    Sujet du message: Mises à jours allplan 2014 Répondre en citant
allez à la tienne !
MessagePosté le: Jeu 28 Nov 2013 - 15:59    Sujet du message: Mises à jours allplan 2014 Répondre en citant
En français dans le texte, ça veut dire quoi?
MessagePosté le: Jeu 28 Nov 2013 - 16:14    Sujet du message: Mises à jours allplan 2014 Répondre en citant
brion je pourrais te le traduire via Google mais c'est tellement plus faciel et direct facile de le faire toi même dans ton navigateur ...Tu clic droit sur le texte en vert et tu fais traduire avec "selon ton navigateur et le moteur de recherche associé " et hop comme par magie cela passe en Français dans une autre page qui s'ouvre (en mauvais Français mais c'est compréhensible )
MessagePosté le: Jeu 28 Nov 2013 - 16:43    Sujet du message: Mises à jours allplan 2014 Répondre en citant
T’inquiètes pas Phil, je connais la manip  Wink , mais c'était histoire de te faire râler
Ceci dit, la traduction Google est parfois incompréhensible et marrante:
Data Conversion
est traduit par:
Conversion des données
Conversion de données de fichiers de dessin contenant associative considère ce améliorée.
Élément en détaillant les fenêtres sur les modèles s'affichent correctement à nouveau.
Lorsque vous mettez le programme à Allplan 2014, la date de conversion des sorciers dans le bureau ce niveau amélioré.
Moi je préfère les sorcières, même si elles sont moches... Evil or Very Mad
MessagePosté le: Jeu 28 Nov 2013 - 16:50    Sujet du message: Mises à jours allplan 2014 Répondre en citant
ah d'accord , je vois mÔssieur est peu regardant sur la qualité !! Very Happy
MessagePosté le: Jeu 28 Nov 2013 - 17:00    Sujet du message: Mises à jours allplan 2014 Répondre en citant
j'utilise Bing translator qui semble etre un peu mieux ..
http://www.bing.com/translator/
Code:
Data Conversion
Code:
Conversion de données de fichiers contenant des vues associatifs de dessin a été améliorée.
Éléments en détaillant les fenêtres sur les mises en page sont affichés correctement à nouveau.
Lorsque vous mettez à niveau le programme d'Allplan 2014, la conversion des données d'assistants au bureau standard a été améliorée.
MessagePosté le: Jeu 28 Nov 2013 - 17:08    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Effectivement, Bing à l'air de mieux traduire;
pour une fois que Microsoft fait quelque chose de bien, il faut le souligner
MessagePosté le: Jeu 28 Nov 2013 - 17:47    Sujet du message: Mises à jours allplan 2014 Répondre en citant
si Microsoft n'avait pas existé , tu serais encore à dessiner avec tes crayons HB/2B sur du contrecalque !! Wink
MessagePosté le: Jeu 28 Nov 2013 - 18:03    Sujet du message: Mises à jours allplan 2014 Répondre en citant
Je suis, pour une fois, entièrement d'accord avec toi Phil : sans Internet Explorer, on ne pourrait pas télécharger Chrome Mr. Green
MessagePosté le: Jeu 28 Nov 2013 - 18:10    Sujet du message: Mises à jours allplan 2014 Répondre en citant
ne me dit pas que tu fais parti de ces gens qui se servent de chrome ,le truc le plus insidieux pour te fliquer à mort ..non pas toi !! Very Happy
MessagePosté le: Aujourd’hui à 07:16    Sujet du message: Mises à jours allplan 2014
Page 1 sur 13
